SLIP and VDC light no acceleration! HELP!
Old Jul 4, 2006 | 03:19 PM
  #31
ttrank's Avatar
Grocery getter
Originally Posted by dmitrius
Hey guys im new member here. Been checkin out this site and it rocks! Where is the throttle body located cause i ran into the same problem once and figured i could tighten up the bolts.
Welcome!
The TB is at the top of your intake right before it goes into the plenum. Just follow your intake tube up and you will see it.
Look at the picture below. It is at the end of the CF intake tube behind the IC hose on the right of the blower.
?action=view&current=DSC06576.jpg&refPage=&imgAnch=imgAnch4
Old Jul 5, 2006 | 08:09 PM
  #32
MSO4's Avatar
Just happened to me this weekend, SLIP/VDC lights all came on, engine RPM would increase VERY slowly even when I floored the gas. Turned off the car and restart, everything fine except SES light. Yesterday, the light went off. I was about to cancel the appointment but maybe I should bring my car in for a new sensor or something.
Old Jul 5, 2006 | 08:21 PM
  #33
carbrite's Avatar
I have the same problem i think... when i take a hard turn and my vdc/slip light comes on... I have no acceleration... when the light goes off acceleration is normal...
should i take it in?
Old Jul 5, 2006 | 08:24 PM
  #34
driguez's Avatar
it seems a lot of people are having this problem, mods, maybe you wanna consider making this a sticky
Old Jul 29, 2006 | 07:52 PM
  #35
ymisotall's Avatar
Had the same thing happen to my 2005 G sedan today. I was driving normal for 10 minutes, parked it and when I started the car again, the SES light came on along with SLIP and VDC light. It seemed like wasn't able to accelerate in 1st gear (i have an automatic) but after it gets going slowly i was able to accelerate rather slowly.
After reading the boards, sounds like it's a throttle body issue. I'll need to take it in ASAP to get this fixed. Would this covered under warranty? Thanks.
Old Jul 29, 2006 | 08:09 PM
  #36
ymisotall's Avatar
Continuation of my previous post: After I get to my destination, I shut off my car for about 15 minutes. When I return, i start the engine and the SLIP and VDC lights are gone but the SES light remains. I am able to accelerate as normal. This is the first time it's happened.
Again, after reading the boards, it seems like a throttle body issue. Is it safe for me to drive the car after experiencing what I just described? Thanks.
Old Oct 13, 2006 | 10:40 PM
  #37
nchaurdia's Avatar
i just got my 20s put on and as soon as i pull out..two signals later..the slip light comes on and i can't accelerate..i slowed down pulled over and decided to turn VDC off and then continued driving home...and it was fine. this was when i was going from second to third gear.
do i go to the dealer which is like 60 miles from me?
Old Oct 13, 2006 | 11:26 PM
  #38
andy2812's Avatar
I have an 05x and was on the way to the dealer this morning to get an oil change and both the VDC OFF and SLIP lights came on. However, I didn't have any loss of power when the lights were on. I stopped for gas and when I turned the car back on the lights didn't come on again. I mentioned it to the dealer and he immediately said that I might need front brakes. Since I knew that the car would need brakes soon, I wasn't surprised when they told me it needed brakes. The dealer said something to the effect of that when the brakes wear down, the skid control system shuts off to allow for the extra compression the capilers have to make before the brakes kick in.
Of course this is now another side effect of having a car whose brakes wear prematurely. I have 22K miles and am about to put a 4th set of brakes on the front and third set on the rears.
Old Oct 14, 2006 | 02:24 PM
  #39
ttrank's Avatar
Grocery getter
What size tires do you have on your 20's?
Old Oct 14, 2006 | 08:22 PM
  #40
nchaurdia's Avatar
245/35/20 & 275/30/20
staggered setup! now also my tire pressure light is on...
Old Nov 7, 2006 | 03:25 PM
  #41
OvaYahead's Avatar
sorry to bring an old thread to life, but this can also happen if the Mass Air Flow sensor is not attached correctly or broken.
Old Nov 7, 2006 | 03:32 PM
  #42
Floyds_racing's Avatar
The exact same thing happened to me last night!!! LOl
Old Dec 2, 2006 | 02:07 PM
  #43
acs2's Avatar
mannnnn
exact same thing happen to me yesterday at a intersection....
the VDC light and SLIP light both went on....
couldn't accelerate at all...start up the car 5-6 times....and finally
allowed acceleration...yet the cars behind me kept honkin at me..quite scary..lol
i think i'll just take it into the dealership..
Old Dec 2, 2006 | 09:08 PM
  #44
gwhiz35's Avatar
You should still be covered by the powertrain warranty, unless your mileage is sky high.
Old Dec 27, 2006 | 10:18 AM
  #45
Nate99's Avatar
Newbie here, bumping up an old thread, but adding to the list of another '03 sedan with the same issue (minus the limp home mode).
We did put on a set of 225/55/17's in place of the 215/55/17 stockers (slightly different height) a while back, but I don't think that the lights were concurrent with the tire change
