Are Aero Painted Sidesills = 03-04 Sidesills?
Old Sep 27, 2005 | 02:34 PM
KayGee56's Avatar
do dealerships handle painting the front, rear and side stock rubber parts or did you guys do all the painting yourselves?
Would that look right without getting any aftermarket pieces?
Old Sep 27, 2005 | 03:19 PM
tgenius's Avatar
Originally Posted by inTgr8r
I got the Nismo for abou $890 shipped
The painting you should be able to get for $3-400
You got the color coded Nismo Bumper for 890?!!?! Did you talk with Justin over there?
Old Sep 28, 2005 | 09:12 PM
wanalaugh74's Avatar
Front is Nismo.
Everything else is OEM
Did u put it on youself? Did you have to jack up the car and cut the metal? if so, how did u cut the metal piece? thX
Old Sep 29, 2005 | 09:13 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
I did install myself....
Didn't have to jack up the car.
What metal are you referring to?
The 1" extensions on the bumper frame?
Old Sep 29, 2005 | 10:29 AM
Rickebob's Avatar
Gotta go to the body shop. Those painted sills look great.
Old Sep 29, 2005 | 10:53 AM
Yea that metal piece. DId you buy new clips or use the one that held your old bumper in. How many pieces were there in the wheel well that you needed to remove to get the bumper off \?
Old Sep 29, 2005 | 11:06 AM
InTgr8r's Avatar
No clips needed, don't know what you're thinking??
- It bolts up the same as the regular bumper.
- 2 bolts in each wheel wells + all the rest
- you need to take off the side marker bracket & pop-rivet to the Nismo
- there's 4 plastic duct pieces that come off (behind OEM)
- you need to trim about 1" from the bottom of the aluminum square stock at each end of the support frame.
It helps to have an extra pair of hands when putting on the car;
fittment is tight.
That's about it...
Old Sep 29, 2005 | 11:09 AM
Ahhh.. my bad.. i was thinking in "Acura" mode. I just replaced my wifes MDX front bumper and used clips.
You think i will be able to reach the bolts in the well with 19's?
Old Sep 29, 2005 | 11:14 AM
InTgr8r's Avatar
Ya.. no problem.
Just turn the wheel & bend the plastic back a bit.
Works evan easier if you have a long socket extension.
Old Sep 29, 2005 | 11:22 AM
Sweeet thx for the heads up. Gonna try to do it this weekend.
Old Sep 29, 2005 | 12:04 PM
Picus's Avatar
Staff ALUMNI
This site is the devil.
Old Oct 4, 2005 | 09:09 AM
Ok, so i got the front aero on, but got a few questions.
1. How come I got left over a couple of extra bolts and clips? I think I took too many off. Does the Aero bumper use less clips/bolts?
2. Why didn't anyone tell me i needed a rivet gun? lol I had to drive to Lowe's with no bumper. hahah
3. WHy is this bumper so PHAt!!!!
I'll post pics later when I get my sides and rear done. I love this thing!!! It definitely makes my car go faster.. LOL jk
Old Oct 6, 2005 | 12:25 AM
kingpin17's Avatar
My bumper is on order...how long did it take you to do the install? Rivet gun?
Old Oct 6, 2005 | 08:44 AM
If you subtract the 1 hour i wasted going to Lowe's and getting the rivet gun, it only took about 1.5-2 hours. I didn't have jack stands so it took me a little longer to get to the bottom clips and bolts. Real straight forward. If you got the OEM Aero, then it is a perfect fit. The hardest part was getting to the 2 screws in the wheel well that hold the bracket for your side markers. If I would have taken my wheels off and used stands, then it would have been no problem. But it is very do-able. It was one of those nuts that you can use a rachet for but also had the middle carved out for a phillips screwhead (if that made any sense).
hope this helps.
Old Oct 8, 2005 | 09:59 PM
  #30
kingpin17's Avatar
Thx...my bumper should be in sometime next week. I will post pics of my '05 tail install tomorrow.
K
