heated seats
Old Oct 7, 2005 | 01:56 PM
LuXXXz's Avatar
heated seats
i just recently started to use the heated seats in my car and a while ago i heard people complaining that only the bottom of the seat gets warm.
When i turned it on yesterday the back support on my seats gets warm too.
Old Oct 7, 2005 | 02:34 PM
MikeyMike's Avatar
Rollin On Dubz
The heat warmers on the Lexus, Acura, BMW, even VW, make's the G's feel like SH*T.
Old Oct 7, 2005 | 03:18 PM
LuXXXz's Avatar
i dunno my buddy has a 04tl and the seat warmers are just about the same, im not sure if even the LOW setting on my G is better then his LOW setting, because i never kept it on HI for more then a couple of minutes
Old Oct 7, 2005 | 03:24 PM
erikill's Avatar
volvo seat warmers are the best (in the older ones at least). Sweeden is a VERY cold country and if you disconnect the sensor you can burn your butt hahah.
G's I tried yesterday, they were slightly warm on high, but maybe they are linked to temperature, so a cab temp > 60 F would be warmer?
Old Oct 7, 2005 | 04:01 PM
LuXXXz's Avatar
that could be a possiblity too right??
i mean if you have the heat set on 90 then maybe the seats get warmer too
Old Oct 7, 2005 | 06:40 PM
DP03's Avatar
I seriously doubt the seat warmers are variable with the temp controls. I may be wrong, but most have two settings, warm and warmer, and each setting is fixed.
Personally, I couldn't give a darn about this feature, cause even on the coldest of days I don't use it. What I'd rather have is the ventilated seat feature, like in the new IS350.
Old Oct 8, 2005 | 08:20 AM
Corgidog's Avatar
THe heated seats in my 05 just get warm. If this as good as it gets or are mine defective. I have not tried them in cold weather yet.
Old Oct 8, 2005 | 11:45 AM
JimG35's Avatar
These seat warmers work well. But it's so easy to whack the on-button without knowing it & your notice when butt starts getting hot. (BMW warmers get so hot you need to shut-off withing a couple of minutes.)
Old Oct 8, 2005 | 12:05 PM
allforthecash's Avatar
Agreed....the 330ci heated seats you can cook a steak on...okay maybe not .. ......but they do suck in the G....reasons why bmw is better mauauhahahahha
Dallsinghjr1
Sep 17, 2023 11:25 AM
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
DRG35R
Jan 31, 2016 07:14 AM
hrdwirk1
Oct 2, 2015 06:34 PM
doakley92
Sep 25, 2015 12:58 PM
