Deodorizing Vents
Old Mar 22, 2006 | 03:19 PM
gary c's Avatar
Originally Posted by doogie
Wait, smoking's not good for you? WOW! I'm gonna quit RIGHT AWAY! Thanks for the new info!
Can't believe I've been smoking all this time without even knowing that.
Wholly crap Texan now you know, isn't knowledge
a wonderful thing? Now you may not be pukeing
your lungs up in 10 years!
Old Mar 22, 2006 | 03:28 PM
Twilight35x's Avatar
Originally Posted by 53G35
While looking at a used RX330 at Car Sense ("like-new" off-lease used retailer), it smelled of smoke.
Carsense? Where are you from? Philly, PA area?
Old Mar 22, 2006 | 03:41 PM
Jeff92se's Avatar
Red Card Crew
Cripes. Can you two take your little 2 man circle jerk to private messaging and leave a relatively clean thread alone?? This is EXACTLY the type of crap that makes SEARCHING a HUGE pain.
Old Mar 22, 2006 | 04:03 PM
driguez's Avatar
Originally Posted by jimmyc13
Is sending vapor/mist into the car's AC/vent system bad for the car? Just curious...I like the Febreeze idea...but don't want to F up my car.
Won't you end up with febreeze residue in the circ system? That stuff is a sticky mess when we sprayed it generously on some flooring and carpet where we had some animal butt control issues...love the stuff but that much concentrated can not be wonderful for the system or filters.
so anyone knows about this??
Old Mar 22, 2006 | 04:05 PM
Picus's Avatar
Staff ALUMNI
Well I don't know for sure, but I can honestly say that I've been doing this in mine and customer cars for years and have never had a problem. I brought it up once with a service guy and he basically shrugged and said it was no problem and that the ventilation system sucks in way worse stuff than febreeze every day.
Like I said, I doubt it's worth worrying about. The ventilation system is deisgned to deal with environmental contamination, so febreeze just doesn't strike me as a problem as long as you're not spraying it directly on to your air filter.
You guys don't have to do it, just a suggestion. I've never had a complaint.
Oh, and fwiw, after I do this the car doesn't seem to shoot febreeze odor out of the vents (which would indicate maybe some residue sticking in the system). I'd imagine it's very much like spraying some into the air - it just dissipates before it hits the ground. I use a whole bottle because I do it every 6 months, but i'd guess that a smaller burst more often would do the trick just as well.
Old Mar 22, 2006 | 04:08 PM
Jeff92se's Avatar
Red Card Crew
Agreed. The vent systems are semi-contained. It's mostly just ducting and the cabin filter.
Old Mar 22, 2006 | 08:06 PM
shredX's Avatar
You said "circle jerk" He he he. These forums do go off topic....OFTEN.
In regards to fabreez... My wife has the stuff for inside our house, but it's a standard spray bottle. Do they make an arisol can, or do you sit there and manually spray an entire bottle?
Thanks!
Old Mar 22, 2006 | 10:06 PM
Picus's Avatar
Staff ALUMNI
Thanks!
There are aerosols.
Old Mar 24, 2006 | 07:05 PM
Jeff92se's Avatar
Red Card Crew
Update. I still could smell a faint smoke stink when running the defrost system w/ the fresh air vent. I didn't run the Ozium though there that long the first time.
so I repeated the whole process I mentioned again. But this time sprayed the ozium more aggresively. I also took off the battery cover and tray under the hood. This reveals the fresh air vent and cabin filter. With the ac on full blast and running both defrost and the other heat vents, I sprayed the Ozium toward the cabin filter.
It's been another 2 days and so far it's working. I'm going to now clean all the plastic and leather with cleaner. As I think the vents aren't spewing stink on everything. hehe
Old Mar 24, 2006 | 08:22 PM
shredX's Avatar
^^ Nice. My dad (a smoker) is selling his ride. I gave him the advice from this thread.
Thanks guys.
Old Mar 25, 2006 | 12:21 AM
Texan1's Avatar
Q50 Red Sport 400 RWD
WTF--that was not me. I do NOT smoke
Old Mar 29, 2006 | 04:11 PM
Jeff92se's Avatar
Red Card Crew
One last update. It's been 4-5 days since the last treatment and I haven't had a chance to clean the leather. When my bro rode in the car I asked him if he could smell anything. He said "no". Just a faint smell of the ozium. I agreed but since I drive the car everyday, I couldn't be sure.
So I'm pretty confident that the ozium worked pretty good. I DID however clean the headliner and glass previously. But the 2 treatments of Ozium seemed to do the trick better than anything else I tried
Thanks guys.
Old Jun 13, 2006 | 04:40 PM
Jeff92se's Avatar
Red Card Crew
Ugh! The smell is back. It's not a smoke smell. More like a monkey pissed inside the vents! I'll try the Ozium thing again but has anyone had a persistant problem? I'm thinking something in the system is causing the odor and unless I get that, it will just keep coming back.
Once I run the AC or fan for a bit, it goes away. ?????????
R1 Autoworks
Exterior-Vendor
Jul 3, 2019 07:16 PM
Herbbie Hablib
Forced Induction
Dec 10, 2015 06:17 PM
Learned Hand
Oct 1, 2015 09:02 AM
Jcruzg35
Sep 26, 2015 04:47 PM
master111
Sep 25, 2015 08:32 PM
