Replacing Shift Knobs: Gear Shaft Size?
Old Oct 15, 2005 | 12:12 AM
G35_Girl_69's Avatar
Replacing Shift *****: Gear Shaft Size?
Just wanted to see if anyone knew if the MOMO F16 EVO TITANIUM SHIFT **** would fit in the 2003 g35 Sedan. It says that the shift **** will fit any gear shaft that is less than .60" in diameter.
If it does, which do you guys think looks better?
Here's my car's current center panel setup...
http://www.autotrader.com/fyc/img_po...es=4&advanced=
Here's the F16 Evo...
http://cgi.ebay.com/ebaymotors/MOMO-...ayphotohosting
And heres the Black leather shift ****. (not the silver one)
http://cgi.ebay.com/ebaymotors/ws/eB...ayphotohosting
Old Oct 15, 2005 | 08:45 PM
5150DS's Avatar
If that's a picture of the interiort of your G: The F-16 looks like it is for a manual transmission. The second one says it won't work with an automatic that has a button on the side.
Old Oct 17, 2005 | 03:50 AM
skeleton_cru's Avatar
Sedan
The F-16 **** won't work, but the second MOMO shift **** you posted will definitely work. Several members, including myself, have the MOMO A/T shift ****. I actually bought mine from LTB Motorsports so I know they are reputable. Watch out for replicas on eBay.
Old Oct 17, 2005 | 04:36 PM
Thanks for the info, problem is when I was reading the description, it specifically said that it doesn't work with cars which have the side button on the shifter. You saying it works regardless?
Thanks again.
Old Oct 17, 2005 | 05:48 PM
basus's Avatar
Is there a similar one for the MT. I am looking for one which is shorter in size.
Thanks
Old Oct 17, 2005 | 06:08 PM
Lip's Avatar
Lip
Interesting topic-
I'm still trying to find out if a M35/45 shift **** will fit on my G-
The linkage itself seems shorter, or is it just th ****?
Either way, I would like to find an option like this for Nissans-
http://www.supremepower.com/category/spr/spr-tip.html
Old Oct 17, 2005 | 08:06 PM
Sedan
Thanks again.
Yes, it works regardless. Like I said, several members (including myself) have this shift ****. Once you take off the stock shift ****, you'll see that the plunger mecahnism is at the top and plunges down.
arora_g35
Apr 16, 2026 02:52 PM
madmax032
Drivetrain
Jan 18, 2016 10:41 AM
marsman328
Northern California
Aug 11, 2015 07:29 PM
KevinnnVo
Jul 28, 2015 06:29 PM
