Would 19x8 by 19X10 Rims Fit A Sedan?
Old Oct 21, 2005 | 05:48 AM
SMOKEDLEX's Avatar
mike beyah, this will help you out once you figure out the offset of the rear wheels
http://g-owners.com/article_read.asp?id=27
Old Oct 21, 2005 | 05:50 AM
SMOKEDLEX's Avatar
according to that article a +55 offset on a 10" would still rub but not as much as a +45 so make sure u get the 55
Old Oct 21, 2005 | 08:30 AM
skeleton_cru's Avatar
Sedan
Depending on the tires, you could probably avoid any fender rolling with the +55 offset.
Old Oct 21, 2005 | 08:47 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
Originally Posted by MikeyMike
Is that kinda stagger really that extreme? 8 front and 10 back? I would think having such wide rears would equal really good handling.
That is a perception that many have.
With large rears the car will plough.
(adj. sways will let you tune this somewhat)
I used to run a slight stagger 225 front and 245 rear.
I now run 255 all around & the handling is amazing; much more neutral.
When I get into the twisties now, it says gimmie, gimmie, gimmie..
Old Oct 21, 2005 | 02:13 PM
DaveB's Avatar
Yeah, it is pretty extreme. 1" (8 front and 9 rear) is about all you want to go and ideally you'd want shift that 9" rim offset so that you've only increased the rear track by 1" or less. With the stagger you're thinking about, you could possibly increase the rear track by 2" to 2.5" overall and assuming you're increasing the front track by 1" to 1.5". Having wider rims and a wider track will basically overwork the front tires and will induce more understeer. With the stagger you're proposing, understeer could increase by quite a bit. It may look really cool, but from a performance standpoint, it won't be very benefical.
You can tune out some of the understeer by airing up the rears a bit more than the fronts and getting adjustable swaybars, but it's more a Band-Aid fix and really isn't ideal because of the twitchy behavior the car may exhibit.
Old Oct 21, 2005 | 03:45 PM
MikeyMike's Avatar
Rollin On Dubz
I'm not really trying to mess with sway bars, I used to have them on my car and I ended up selling them, but they did help a lot, I used to hit 90 degree left turns doing 65-ish with rims, drop, and sways, with no tire squeal whatsoever. Now I've got a drop, and I just need some nice rims to complete the look. I guess I am gonna just hold off on these rims for now because of the understeer and rubbing issues...Thankyou for all your help guys.. I'll be sure to post again when I find another set of rims I want, lol.
Old Oct 21, 2005 | 04:04 PM
Chico's Avatar
If you don't want to go staggered...DPE and IFORGED can do 8.5 all around with a staggered offset, so you get a bigger lip in the rear but you'll keep same size tires all around.
That would be your best solution for looks and performance. I know they custom fit everything they make so don't worry about the offsets just tell them what you want and that you like MAX lip front and back.
Old Oct 22, 2005 | 03:54 PM
MikeyMike's Avatar
Rollin On Dubz
I'm honestly pissed off at DPE now...why would they make 19x8 by 19x10 rims if it would cause so much understeer?
I've seen quite a few members with DPE's running this set-up...what are the positives?
Old Oct 22, 2005 | 04:08 PM
6mtpnut's Avatar
Originally Posted by vodkarocket
When I spoke with Vince from iForged, I was told that they were able to get a set of 10" wide wheels to fit with a 49mm offset with fender rolling.
yup, my buddy has them.. fenders are rolled all the way though
Old Oct 22, 2005 | 10:34 PM
Sedan
Those members have coupes. Coupes are designed to have a staggered set-up.
Old Oct 24, 2005 | 02:35 AM
MikeyMike's Avatar
Rollin On Dubz
The coupe suspension is really that different from the Sedans? I guess you're right, they come from the factory staggered.
How about rims that are....
2 Front wheels - 19 x 8.5 + 25 offset
2 Rear wheels - 19 x 9.5 + 25 offset
2 Front - 245 /35
2 Rear - 275/35
On my dropped sedan?
Old Oct 24, 2005 | 02:38 AM
MikeyMike's Avatar
Rollin On Dubz
I keep re-reading this post...so basically staggered on the sedan is just a big no-no? Is that the general concensus?
Old Oct 24, 2005 | 09:29 AM
Sedan
2 Front - 245 /35
2 Rear - 275/35
No way. The offsts to those wheels are for a coupe.
If you want a stageered set-up for your sedan go with the tried and true:
19x8.5 +38
19x9.5 +45
multimut
Wheels & Tires CDN
Apr 8, 2018 06:07 PM
Mkhlmnn
V36 Brakes, Suspension, Wheels & Tires
Aug 1, 2015 12:00 PM
BlackGee35
Jul 31, 2015 11:04 AM
CrazyLogic219
Jul 23, 2015 10:58 AM
