$500 suspension setup
Old Oct 22, 2005 | 10:57 PM
Nickk6's Avatar
Is there a good suspension setup for $500-650? I am selling my old Enkei 18" rims from my Altima to someone for $500, so I figure I am going to do a mod with the money. I am looking to get a shock/spring combo that will increase handling, not ruin the ride and lower it about an inch-inch and a half in front and whatever corresponds to the rear. Coilovers are not necessary.
Old Oct 23, 2005 | 01:49 AM
Teeter's Avatar
You can get the Tein H-Tech/Tokico D-Spec combo for $640 through Everything G35. A lot of performance for not a lot of dough.
http://infinitipa.zoovy.com/c=6yE7vi...SUSPENSIONKIT2
Old Oct 23, 2005 | 04:23 PM
SMOKEDLEX's Avatar
i know if you look around you might be able to find tein basic coilovers for about $500-700 .
Old Oct 24, 2005 | 04:48 PM
dklau33's Avatar
I'd only get that combo if the H-Techs are for the 350Z. The ones for the G35 are sprung too softly.
Old Oct 24, 2005 | 07:21 PM
Nickk6's Avatar
Too soft? Well I want to keep some ride comfort. I think I may end up going for the Tokicos and S-Techs.
Old Oct 24, 2005 | 08:02 PM
jaspergtr's Avatar
for parts, that setup is around $600 (including shipping if out state, blah, blah). but install can run you another couple hundred.
Old Oct 24, 2005 | 08:09 PM
Nickk6's Avatar
I am not worried about install, I can get it done cheap or I have access to a lift and tools if I need to do it myself.
Old Oct 24, 2005 | 08:19 PM
jaspergtr's Avatar
good luck. let us know which one you get.
Old Oct 24, 2005 | 08:30 PM
EverythingG35's Avatar
You can get the 350Z H-tech's in that combo for the same price (I updated it to show that)
That's a good setup. But so are the Tein Basic's for a little bit more, like someone else recommended. They're a bit stiffer spring wise (503/503 vs 358/375) they offer ride height adjustment, valving it matched to the spring rates/car, and they can be overhauled too.
Old Oct 24, 2005 | 08:54 PM
dklau33's Avatar
Well you did say you wanted to increase handling. I see that you have a 6MT, not sure which year and which model, so I'm assuming you have the stock sport suspension on your car.
Either you have 314/342 spring rates or the revised 314/427 spring rates.
The H-Techs for the G35 are 324/263.
The front is fine but look at the horrible rear spring rate. Transfers quite a bit of roll stiffness to the front.
The S-Techs for the G35 aren't much better at 358/274. Transfers even more roll stiffness to the front!
I'd suggest sticking with the 350Z version if you care about performance.
Old Oct 24, 2005 | 09:22 PM
jaspergtr's Avatar
performance, yes - the z version is stiffer, transfers less weight... but... a little more 'punshing' for every day use. i find the h-techs for sedan are quite comfortable. and the spring rate is not an all encompassing figure on control... but it has a lot to do with the relationship with the dampers. this is why coilovers are usually the perfect solution. as far as the s-techs having a lower rate, it is because it is that much lower and has to be compensated that much more to alleviate the stiffness. a soft spring can also help out with traction as well.
Old Oct 24, 2005 | 09:27 PM
jaspergtr's Avatar
i did actually notice a slight increase in understeer, but i picked an adjustable sway bar setup to compensate for this, and i'm loving it. so i get the lower stance (not too low that my camber is way off), a smooth ride, and just enough oversteer that it is still fun to drive. (i'd rather get the quaife lsd)
Old Oct 25, 2005 | 11:01 AM
mr_ecktid's Avatar
You can get the OEM 05 350Z suspension for around $250 used on my350z.com
sales@czp
Suspension-Vendor
26
Nov 6, 2017 03:04 PM
Herbbie Hablib
Forced Induction
Dec 10, 2015 06:17 PM
ZoominG35
Audio/Video/Electronics
Oct 12, 2015 04:53 PM
AesonVirus
17 Inch
Sep 20, 2015 02:05 PM
JustinMKN1
Sep 18, 2015 03:40 PM
