Replacing my shift knob
Old Oct 23, 2005 | 02:12 PM
basus's Avatar
Replacing my shift ****
With a vodoo shift **** which will reduce the height by 1 inch
is it easy to remove the stock ****, i have a manual transmission, has anyone done it and can u let me know exactly how to do
Thanks
Old Oct 23, 2005 | 02:15 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
Wrap the shaft with something soft to protect it,
hold it with pliers & turn the **** off.
Old Oct 24, 2005 | 06:04 PM
basus's Avatar
Which way do i need to turn the **** , clockwise or anti clockwise-- am worried that it should not break
Thanks
Old Oct 25, 2005 | 01:25 PM
basus's Avatar
Can someone reply how do i get the shift **** off , its a manual transmission, which way do i need to turn it
Old Oct 25, 2005 | 02:26 PM
giddyup69's Avatar
counter-clockwise... just like any ordinary nut and bolt.
Old Oct 25, 2005 | 02:37 PM
lowrider's Avatar
To the left, and it's important to immobilize the shaft as stated above, otherwise you could screw up the linkage while taking off the ****. To get to the shaft, you must pop up the trim piece that fits around the boot and crawls up into the dash. It's easy to do. Hold your fingers on the trim piece and push down in the boot area.
Lou
Old Oct 25, 2005 | 04:10 PM
doogie's Avatar
Another Brit on the board?
Old Oct 25, 2005 | 08:52 PM
RetAF's Avatar
Talking
Lefty loosey, righty tighty...
Old Oct 26, 2005 | 11:21 PM
marksg35's Avatar
I used an adjustable wrench[cresent]with a rag on the shift ****.The **** was very tight.I guess Nissan/Infiniti likes using alot of threadlock.Turn counterclockwise.
Mark
Old Oct 27, 2005 | 11:52 AM
dholly's Avatar
Simply attempting to twist the **** off can cause damage to the linkage. It is enough of a concern that Nissan NA put out a Service Procedure Bulletin to do it correctly. See attached.
Attached Thumbnails Replacing my shift knob-knob.gif   Replacing my shift knob-knob2.gif
Last edited by dholly; Oct 27, 2005 at 12:07 PM. Reason: (Mods - info not in DIY Forum, hint)
Old Nov 2, 2005 | 04:50 PM
basus's Avatar
Thanks everyone for your feedback, had it installed and looks great and shifting has become much better, how do i upload a picture.
Old Nov 2, 2005 | 05:02 PM
basus's Avatar
Here are some pics
Let me know how it looks
Attached Thumbnails Replacing my shift knob-knob1.jpg   Replacing my shift knob-knob2.jpg
Old Nov 2, 2005 | 05:06 PM
basus's Avatar
One more
Old Nov 3, 2005 | 02:01 PM
bww1980's Avatar
looks perfect, it matches the trim very well, can you tell us what brand it is?
benjamin
Old Nov 3, 2005 | 02:39 PM
basus's Avatar
Heres the link to the wesite
http://www.ricks2k.com/products/shiftknob.php
Not only it looks classy but it shifts much better than the stock ****
