Smudge on Inside of Speedometer Display
I was using a glass cleaner on the dash display (the glass covering the speedmeter/ RPM/ etc). Somehow, the cleaner went inside and left a 2-inch smear on the glass from the inside. It is really unpleasent to the eye
. To wipe it off, I will have to remove the display and clean it from the inside. Is this hard to do? Also, will dealer clean it under warranty? You would think these displays should be sealed prove from liquids.
Thanks.
. To wipe it off, I will have to remove the display and clean it from the inside. Is this hard to do? Also, will dealer clean it under warranty? You would think these displays should be sealed prove from liquids.Thanks.
DEMoLITIoN
Audio/Video/Electronics
Apr 20, 2016 06:57 PM
Learned Hand
Oct 1, 2015 09:02 AM
