vehicle information system problem
Old Nov 20, 2005 | 12:27 PM
carbrite's Avatar
Just got my 06 x and i have a question re: the vehicle information system. On the fuel information page, when i am stopped i am pretty sure that the km/l fuel economy rev meter should go down to zero... when i am at a standstill the fuel economy rev meter goes up to 15... when i switch the units to mpg it seems to work fine... does anyone know of a reset for this... am i totally off in what i think should be the case???
thanks
Old Nov 23, 2005 | 04:05 PM
bocatrip's Avatar
I cannot answer your question but was wondering if you can answer one for me. I assume you have Nav. Does the information center give you any readings on the tire pressures for each individual tire? If not, what other info does it give? Thanks.
Old Nov 23, 2005 | 05:16 PM
Msedanman's Avatar
O.F. Administrator
thanks
I think your fuel economy meter should go to max consumption while stopped, but then gradually go down as your speed increases.
Welcome and g/l with your new X.
C.
Old Nov 25, 2005 | 05:58 PM
JimG35's Avatar
"Fuel Consumption" gauge simply reads intake manifold vacuum. The more you press the gas pedal, the less the vacuum (which equates to less milage per gallon/liter). IT's not high tech computer "calculations". Another very inexpensive gadget to impress buyers as being 'high tech'. It's a novelty.
Old Nov 26, 2005 | 08:00 PM
carbrite's Avatar
it does not give readings on the tire pressures, which sucks (I thought that it would, my Murano does)... it has maintenance info, fuel, nav version, where am i ... i cant remember the rest though... i'll check and post later.
mike730
Jan 12, 2018 04:25 PM
derres
Aug 28, 2015 03:27 PM
Team STILLEN
Aug 10, 2015 08:17 PM
joedaddy1
Jul 28, 2015 02:58 PM
