Foose Wheels
Old 11-28-2005 | 09:50 PM
Capthook's Avatar
Foose Wheels
Would Foose Speedsters 20x9.5 or 20x8.5 fit on a 05 sedan. I want something with a nice lip. Thanx for the help.
Old 11-28-2005 | 11:24 PM
G35Papa's Avatar
A taller wheel won't give you a bigger lip. Its based on the offset of the rim. I think (but I will leave to the more experienced folks on this site to verify and correct me) that the widest you can go in the front is an 8.5" with a +40mm offset.
The rear will fit up to a 10" with a +44mm offset?
Old 11-29-2005 | 12:49 AM
Gdup35sedan's Avatar
ENVautoDetailing.com
I used to want the foose speedsters, they would be super nice in black, and yes they would fit the sedan, just get the right offset.
-GP-
Old 11-29-2005 | 01:09 AM
skeleton_cru's Avatar
Sedan
Depends on the offsets.
Old 11-29-2005 | 06:27 AM
perry05G35's Avatar
That offset will work with the 10" wheel in the back and up front nothing over 8.5"
Old 11-29-2005 | 10:54 AM
Sedan
Which offset??? The 10" wide wheel with a +44mm offset will NOT work. It will stick way out from the fender. Shoe horning a 10" wide wheel in the rear will require a much bigger offset, like +55mm. perry, check your facts before you dole out bad advice.
Old 11-29-2005 | 11:06 AM
InTgr8r's Avatar
Staff ALUMNI (retired)
^^WHS^^
10" will require no less than +55
Old 11-29-2005 | 11:22 AM
Capthook's Avatar
I don't get Offset. Can some explain it 2 me?
Old 11-29-2005 | 11:27 AM
InTgr8r's Avatar
this pic pretty well covers it.
Also go to tire rack in the tech section there is a write up.
Old 11-29-2005 | 11:28 AM
Sedan
Couple of more...
Philly_G35's Avatar
Pretty good description here.
http://www.discounttire.com/dtcs/infoWheelOffsets.dos
Old 11-29-2005 | 11:33 AM
Capthook's Avatar
Well what dose it mean when you guy say +44 or +55. Is there a -44?
Old 11-29-2005 | 11:35 AM
Capthook's Avatar
I should go with the 8.5 with what offset?
Old 11-29-2005 | 11:36 AM
InTgr8r's Avatar
offset measurement in mm
effects the position of the wheel inside the wheel well of the car
Old 11-29-2005 | 11:38 AM
InTgr8r's Avatar
I hav 8.5" with +42
Quick Reply: Foose Wheels
