Fogged headlights?
Old Dec 15, 2005 | 04:39 PM
netwireless's Avatar
Fogged headlights?
I did a search for this and did not find any useful info. It appears my headlights are fogged or have a layer of film accomulated from inside. Is this something that dealer can, and would fix? I believe it would require taking the headlights apart. This is very annoying at nights on an almost new car. Any ideas?
Old Dec 15, 2005 | 04:46 PM
djcrzyc's Avatar
I work at a dealership. If the car is in warranty they will either replace the headlight lens or at least try to clean them up. Usually they replace them. I know where I work we would. Usually the seal breaks letting moisture in the lens causing them to fog up or have that effect. Hope this helps.
Old Dec 15, 2005 | 05:13 PM
Great, I will take it to my dealership to see what they can do. Thanks Djcrzyc.
Old Dec 15, 2005 | 05:31 PM
4thHorseman's Avatar
What dealership, djcrzyc? PM me if you'd rather not show the world. I live in the DFW area.
Old Dec 15, 2005 | 05:34 PM
djcrzyc's Avatar
Park Place Lexus in Plano.
Old Dec 15, 2005 | 05:59 PM
PotomacG's Avatar
I thought mine were "fogged on the inside" until I tried Mcquires Plastic X cleaner on the outside. They now look good as new. Try using a quality cleaner made for plastic headlight covers before you make a service appointment. You may be surprised.
Old Dec 15, 2005 | 06:58 PM
perry05G35's Avatar
I have a simular problem with my G with less than 7K miles on it but my 02 Maxima had the same fog I was told it's a result of my HID with the Maxima so I am assuming a little fog is normal?... However I will give the plastic cleaner a try as well. We only have one Infiniti Dealer in Hawaii and if I keep getting on their nerves they may not let me get a loaner whenever I need service!
Old Dec 15, 2005 | 07:00 PM
GeoBau's Avatar
Cactus Hugging Admin
It's really common, and it's on the outside. Use 3M Clear Plastic Polish, then coat it with a clear plastic detailing spray.
G
Old Dec 15, 2005 | 08:34 PM
Pqbrown's Avatar
Another vote for Plastix, great stuff, makes em look almost new.
Old Dec 15, 2005 | 11:13 PM
kingpin17's Avatar
+1 for 3M Plastic Cleaner. Good as new.
Old Dec 16, 2005 | 02:22 PM
Noremac's Avatar
Also, see the TSB on this issue.
jeffbdye
Jun 1, 2018 03:51 PM
Picture Share
Feb 4, 2018 12:41 PM
9tray turbo
Sep 29, 2015 10:22 PM
Batfinity
Lights
Sep 27, 2015 12:29 AM
