Nismo Sway Bars
Old Dec 16, 2005 | 07:37 AM
jimmykce1's Avatar
Nismo Sway Bars
Anyone installed the Nismo Sway Bars on their G?? What do you all think of this brand sway bar? Does these sway bars come with new bushings??
Old Dec 16, 2005 | 10:15 AM
Gsedan35's Avatar
Here's a post I made on the subject in the past, I edited it a bit. The Nismo sway's do come with bushings.
Originally Posted by Gsedan35
Nismo sway's are not adjustable and do not offer as much stiffness as most if not all aftermarket adjustable sway's in the front. The Nismo rear sway bar is not stiffer then the oem rear bar compaired to coupes that have the 05/06 sport suspension. Remember, part of the 2005 coupe sport suspension package is also stiffer sway's, most likely a stiffer front bar to counter the rear spring rate increase. Simply put, you are better off making another sway bar choice. Sway bars should be used to fine tune the car's at the limit balance to your liking, to YOUR setup. You can only do that with adjustable bars. Stillen, Hotchkis (I'd add collar's to them) and EVO350 are all good choices.
Nismo sway bars vs all oem G35 sway bar's (05/06 coupe sport suspension NOT included)
Front: +18%
Rear: -1%
If I were to bet money on what Nismo sway bar specs are vs 05/06 coupe sport suspension sway bars.
Front 0%
Rear -1%
Picture Share
Feb 4, 2018 12:41 PM
prinny
Nov 22, 2015 11:07 PM
AL8782
Oct 3, 2015 10:26 AM
NyCrAzY
Oct 1, 2015 09:19 AM
