Leaning towards a G35X - What mods can be done?
Old Dec 30, 2005 | 12:26 PM
snadsnad's Avatar
So my basic requirements for a car are AWD and near 300hp/tq and the G35X conforms to this and it looks ****ing classy.
Maybe you guys have a centralized list somewhere of compatible mods, I'm not sure, I've tried searching a decent amount. I don't if this has been posted a thousand times before but what mods are recommended for a G35X? Are there any sites that sells parts/upgrades that you all recommend? My main concern is buying a product advertised for the sedan but not work on the AWD version.
Things I'm looking at are: Exhaust (Stillen?), coil overs (Tein?), any sway bars/strut tower braces, wire grounding kit, intake, and anything else recommended. I'm assuming doing most of this will void my warranty? If it isn't obvious I'm looking for bolt on stuff of course although some of this I might have to take to a nearby shop that does a lot of custom stuff. Would the hardest work be switching out the shocks/struts/springs? My friend and I installed new springs and shocks/struts on my current car about a year ago and it took a good 6 hours with borrowed tools from Auto Zone, lots of socket wrenches, and a breaker bar.
Thanks for any tips and advice.
Old Dec 30, 2005 | 12:37 PM
ChicagoX's Avatar
Don't drink and Mag Race
The Stillen is the only aftermarket full exhaust that I know of that will fit the "X" cars. Anything else from the y-pipe back will fit.
The front suspension is cribbed from the FX35, so a RWD setup will only fit the rear. You might be able to get away with a hybrid f/r aftermarket system.
Most motor mods will work. I love the Motordyne spacer, along with the z-tube/K&N combo.
Good luck with your car.
Old Jan 5, 2006 | 02:55 PM
G-Mony's Avatar
you should be able to do most mods on your list. except, there isnt any applications for sway/strut bars. last i've checked the Stillen sway kit the rear will fit but the front bar wont due to the AWD system.
you could F! too w/ Stillen SC stage 2. no TT.
infinitiway
Aug 8, 2017 12:38 PM
Mad A
Not G35 Related
Dec 8, 2015 01:45 PM
Rhinos7777
Sep 6, 2015 05:36 PM
kevintandmd
Sep 3, 2015 06:41 PM
INVADER_6MT
Sep 3, 2015 01:47 AM
