Switch to synthetic AND still change my oil every 3500 miles...Crazy?
Old Jan 6, 2006 | 08:47 AM
  #106
G35_TX's Avatar
Originally Posted by Jeff92se
Then you have a choice to make. Post a short, unbacked reply and don't get upset when people are critical or take the time to post a complete reply.
I don't need you to tell me how to post Jeff.
Old Jan 6, 2006 | 10:12 AM
  #107
kinglenario's Avatar
wow, you guys change oil a lot . it definitely won't hurt anything but is a bit much. if your running mobile 1 you can very safely go 5,000 miles, then change the filter and top off with 1 quart, and go another 5,000 miles. a lot of the german cars go over 10,000 miles without even a filter change. the sythetic oil just doesn't break down at all. as long as you keep if filtered it's fine.
Old Jan 6, 2006 | 12:03 PM
  #108
Jeff92se's Avatar
Red Card Crew
You sure had alot of time to play footsies with VegasG35sedan earlier. Point being if you spent the same time researching your point, the flame war would have never happened. But alas history repeats itself yet again
Originally Posted by G35_TX
I don't have time to write a book when I am at work or have links of data as well.
But we can say for a store bought oil. Mobil 1 would be the best. But the best oil out there is Amsoil.
Old Jan 6, 2006 | 02:15 PM
  #109
vegasG35sedan's Avatar
05-G35 Sedan 5AT
^+1
Old Jan 20, 2006 | 02:51 PM
  #110
KayGee56's Avatar
Just get the Amsoil ASL SAE 5W-30 and the new EaO12 oil filter and youre set for a year/25,000
SERVICE LIFE
AMSOIL Synthetic 5W-30 Motor Oil is recommended for extended drain intervals in unmodified(1), mechanically sound(2) gasoline fueled vehicles as follows:
• Normal Service(3) – Up to 25,000 miles or one year, whichever comes first.
• Replace AMSOIL oil filter at 12,500 miles or six months, whichever comes first (other brands at standard OEM* intervals).
• Severe Service(4) – Up to 15,000 miles or one year, whichever comes first.
• Replace AMSOIL oil filter at 15,000 miles or six months, whichever comes first (other brands at standard OEM* intervals).
• In all other applications, extend the oil change interval according to oil analysis or follow the OEM* drain interval.
Old Jan 20, 2006 | 05:05 PM
  #111
bythabay's Avatar
I'd recommend against going w/ the ASL... check out the specs:
Kinematic Viscosity @ 100°C, cSt (ASTM D-445) 10.6
Kinematic Viscosity @ 40°C, cSt (ASTM D-445) 57.3
Viscosity Index (ASTM D-2270) 178
CCS Viscosity @ -30°C, cP (ASTM D-2602) 5254
Pour Point °C (°F) (ASTM D-97) -51 (-60)
Flash Point °C (°F) (ASTM D-92) 228 (442)
Four Ball Wear Test (ASTM D-4172B: 40 kgf, 75°C, 1200 rpm, 1 hr), Scar, mm 0.35
Noack Volatility, % weight loss (g/100g) (ASTM D-5800) 6.6
High Temperature/High Shear Viscosity
(ASTM D 4683 @ 150°C, 1.0 X 106 s.-1), cP 3.2
Total Base Number 12.2
If you look at a viscosity chart, you'll see that a 30weight oil goes from 9.30-12.49 @ 100 deg cel.
and a 20weight goes from 5.60-9.29 @ 100 deg cel...
according to this info the newly reformulated ASL is no good for the vq.. it's almost a 20 weight oil!!...
I'd go with something on the thicker side such as the HDD s3k:
11.7
67.6
170
Cold Crank Simulator Apparent Viscosity @ -25°C, cP (ASTM D 2602)
4997
Pour Point °C (°F) (ASTM D 97)
-51 (-60)
Flash Point °C (°F) (ASTM D 92)
230 (446)
Noack Volatility (DIN 51581) 250°C for 1 hour, % weight loss
6.7
High Temperature/High Shear Viscosity, cP, 150°C, 1.0 x 106 s-1 (ASTM D-4683)
3.6
Four-Ball Wear Test (ASTM D-4172: 40kgf, 150°C, 1800 rpm, 1 hr) Scar diameter, mm
0.38
Total Base Number
12.2
derres
Aug 28, 2015 03:27 PM
JoeMac
Aug 20, 2015 10:17 AM
leo38cheng
Interior
Aug 18, 2015 06:30 AM
Bean_VQ35DE
49
Aug 3, 2015 05:17 PM
