2004 Coupe wheels on 2003.5 Sedan
Old Jan 10, 2006 | 10:21 AM
martyb's Avatar
I have searched and found some info on putting 2004 Coupe wheels on a 2003 Sedan, and for the most part it looks like it will work fine. I have the stock suspension. Anyone have any pics of this set up? Are the 2004 Coupe wheel 18X8? Just wondering how they look and if there are any rubbing issues.
thank you
martyb
Old Jan 22, 2006 | 01:52 PM
Gilley's Avatar
Search for posts by Chico. He has coupe wheels, as do I, on his sedan. They will work and sit about flush with the body.
Old Jan 22, 2006 | 04:01 PM
boones's Avatar
They will fit physically, but the offsets are wrong and the sedan should use equal sized tires all around and not a staggered setup like the coupe.
Old Jan 22, 2006 | 08:25 PM
wanalaugh74's Avatar
Why?
Old Jan 22, 2006 | 09:14 PM
vegasG35sedan's Avatar
05-G35 Sedan 5AT
you can stagger the wheels on the sedan,, a lot of folks here have done that and it looks awesome.. they say you cant on the "X" although you could probably stagger the width and offset but the circumference should remain equal on all fours on the "X"..
Old Jan 23, 2006 | 06:13 AM
jerdubois's Avatar
What wheels are you putting on? The 18" or 17" coupe wheels? The 2004 18" have the same wheel all around, but diff tires. The 17" wheels are NOT the same... (diff offset and width). I put these on my 2004 X, but will buy the same tire (more than likely 235s) all around.
vmcarbuyer
Oct 12, 2019 12:42 PM
teamghost
Jul 28, 2015 04:52 PM
Karnicle
Jul 23, 2015 05:08 AM
vstypicals
Jul 20, 2015 10:55 PM
