Removing Clock Finisher (2005 Sedan?)
Old Jan 19, 2006 | 11:09 PM
mhollinger's Avatar
Hey folks,
My rattle / squeak exorcism is still in progress. I've taken it to the dealer perhaps five times, and I think I'm starting to annoy them (and I'm pretty annoyed that the car won't reproduce the noises on test drives with the techs for that matter).
The last time I took it in, I asked for them to do the "rattle / squeak" TSB. The service technician did it, but the felt tape he used is visible. I'd like to take it apart, trim it, and replace it.
I'm curious: How do I remove the upper clock finisher / "cluster lid finisher", and the lower clock finisher?
I have the service manual for the car, but don't know how to open / pop / release / whatever the various clasps that hold the pieces in place.
Any tips on what I should do, and how I should put it back together?
Old Jan 20, 2006 | 12:50 AM
ABQ_G35's Avatar
Be careful with that, they broke a clip on mine when they removed it to do the radio faceplate, it looks pretty fragile under there, see if you can find a DIY guide.
Old Jan 20, 2006 | 07:35 AM
boones's Avatar
I don't know how it works on the 05, since that interior piece is different from 03/04. In 03/04 the service manual gives incorrect instructions on how to remove that piece. It's says:
Originally Posted by Service Manual
For easy removal, hold upper portion of lid, and pull lid upward to disengage metal clip. After that, pull it your side.
But the reality is that it has to be grabbed at the top and pulled straight back towards the back seat, not up. Pulling up would just break the clips. It's a test of faith too, because a lot of force is required to free the clips. Keep in mind this is for 03/04 and may or may not be true for 05/06.
Old Jan 20, 2006 | 09:04 AM
mhollinger's Avatar
The 2005 manual clarifies that:
(F) Cluster Lid Finisher Upper
Pull to the backside, disconnect clips and pawls, and remove cluster
lid finisher upper.
Does this mean "Pull toward the rear of the car" as the person with 2004 mentioned?
(G) Cluster Lid Finisher Lower
Disconnect pawls and clips, and remove cluster lid finisher lower.
If I knew what a pawl was, and how to disconnect it, this would be easier.
I checked around for a DIY guide, but generally there's no reason to get in there for most folks, so I couldn't find one.
I get the feeling that if I were to look under the powertrain section, I'd find something like:
"(A) Remove Transmission: Disconnect from engine and remove."
Old Jan 20, 2006 | 10:07 AM
ABQ_G35's Avatar
The '05 is completely different from the '04.
Old Jan 20, 2006 | 10:50 AM
boones's Avatar
Then help the guy out if you know how it comes apart.
Old Jan 20, 2006 | 12:39 PM
trebien's Avatar
I know how it comes apart - I watched my service tech do it yesterday on my 2005 when we were talking about a...
...drum roll...
...you're not going to believe it...
...a squeak.
Take that upper "lip/lid/whatever".... grab it with your fingers/thumb, and pull straight back towards the rear of the vehicle - it takes a decent pull. The little white plastic clips that are attached to it are re-usable. To re-attach, just slide it back in.
The lower... I can't help you - I'm not sure.
Old Jan 20, 2006 | 01:34 PM
boones's Avatar
...drum roll...
...a squeak.
haha, that's exactly how the 03/04 comes apart.
Old Jan 20, 2006 | 01:42 PM
absolutg's Avatar
workin...
hey guys, i took my car in to get some squeaks/rattles fixed and one was coming from the clock area. after i got the car back, i noticed that the finisher "lid", the part that you can just pulled out horizontally, was very very flimsy vertically. is yours like that too? i mean it just wobbles with very little pressure (and i still have the rattling sound i'm hopefully getting fixed over next weekend)
Old Jan 20, 2006 | 02:06 PM
JoshNjuice's Avatar
Yes, I've noticed the same thing on my car. It seems like the felt tape might be getting in the way of a real tight fit.
Old Jan 20, 2006 | 07:34 PM
mhollinger's Avatar
I've not noticed this, and they've taken it apart twice now. It does move if I apply a decent amount of force on it, but it is by no means loose. I suppose when I get in there, I'll take pictures... If I break it, I've already bought it, so I'm not *too* worried. ;-)
I'm more worried about any passengers I have in the car that might see my broken dash board than if I can fix it if I break it.
Old Jan 20, 2006 | 09:09 PM
ABQ_G35's Avatar
That's exactly what happened to mine, I noticed it and went right back to the dealer, he replaced it with one off another car on the lot!
Old Jan 29, 2006 | 11:16 PM
mhollinger's Avatar
So I removed the finisher, and realized that when whoever installed it last installed it, they didn't hook the "pawls" on either side together, which might explain why the piece wasn't sitting properly.
I did just as the service manual suggested: I pulled straight back, and the piece came right out, somewhat surprisingly. Nothing broke, and nothing was harmed.
The problem now is that I don't know how to remove the lower finisher, and I'm pretty sure that whoever did it last didn't want to bother, since the upper finisher wasn't clipped to the lower.
Does anyone know how this lower finisher piece comes out? Does it come straight up? Where should pressure be applied?
Tolboothwilley™
Exterior-Vendor
Jul 28, 2016 12:42 AM
lemmy999
Jul 25, 2015 12:13 PM
tehmoonrulz
Jul 19, 2015 10:44 PM
Scredeur4
Steering & Suspension
Jul 17, 2015 06:30 AM
