question about wheels
Old Feb 9, 2006 | 02:14 PM
TheTrance's Avatar
I don't have much experince with this. i did look on the wheels forum but couldnt get my answer.....
my question is: im looking for staggered lightweight 18" rims (for SEDAN) that would stick out a little and be wider but i dont wanna deal with any problems like rubbing and such... what configuration should i go for?
thanks!
Old Feb 9, 2006 | 03:34 PM
Hyde's Avatar
get some light weight rims like TE37 and dont run too aggressive offset.
what u want is pretty simple.... getting the deepish dish possible without an aggressive offset is hard.
Old Feb 9, 2006 | 03:52 PM
rupdog326's Avatar
Out of many - one people
The stock sedan wheel offset is 45 for both 17 and 18 inch wheels and the stock wheel width is 7 inch for the 17 inch wheel and 7.5 for the 18 inch wheel. Plug in some numbers in the wheel offset calculator to see different setups.
Old Feb 9, 2006 | 11:13 PM
Gdup35sedan's Avatar
ENVautoDetailing.com
I'd look into Enkei wheels, I personally like the RPF1, they only weigh 18.5 lbs and are reasonably priced. There's also volks (overplayed) or you could try out some Gram Lights, there more expensive but very nice wheels.
-GP-
Old Feb 9, 2006 | 11:28 PM
TheTrance's Avatar
so whats a safe offset to go for?
Old Feb 10, 2006 | 12:08 AM
woshiagni's Avatar
+38 is pretty safe if you run a stretched tire and don't drop it more than about 1.2" -- that would limit you to Eibach Pro-Kit's and Tein H-Tech's though... or get coilovers!
Old Feb 10, 2006 | 01:54 AM
TheTrance's Avatar
Ok so: back 18x9.5 and front 18x8.5 with +38 offset? that works fine without any problems?
Old Feb 10, 2006 | 02:03 AM
skeleton_cru's Avatar
Sedan
Get a bigger offset in the rear if you can. 19x9.5, +45 is good.
Old Feb 10, 2006 | 02:07 AM
TheTrance's Avatar
ok so we stick to front: 18x8.5 +38 and back: 18x9.5 +45
am i limited in the choice for tires? im sort of looking for something low profile....
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
IEMaestro
20 Inch
Jul 30, 2015 04:30 PM
Detailed Image
Jul 24, 2015 12:31 PM
