Throttle Valve Closed Position Learning
Old Feb 12, 2006 | 01:21 PM
obender66's Avatar
Any one have "How to"? I believe I saw post about resetting pedal, ecu and throttle valve positions, but it wasn't "stickied" amd I can't find it.
Thank you
Old Feb 12, 2006 | 01:35 PM
obender66's Avatar
I found the answer:
Perform If Throttle Actuator Is Disconnected
DESCRIPTION
"Throttle Valve Closed Position Learning" is an operation to learn the fully closed position of the throttle valve by monitoring the throttle position sensor output signal. It must be performed each time harness connector of electric throttle control actuator or ECM is disconnected.
OPERATION PROCEDURE
Make sure that accelerator pedal is fully released.
Turn ignition switch "ON".
Turn ignition switch "OFF" wait at least 10 seconds . Make sure that throttle valve moves during above 10 seconds by confirming the operating sound
Old Feb 12, 2006 | 01:46 PM
Msedanman's Avatar
O.F. Administrator
Thank you
All the resets you need are in our DIY/FAQ forum in this thread:
ECU RESETS
Colin.
chinee
Jun 10, 2024 07:48 PM
Muski_G
Dec 1, 2023 11:11 AM
Silver tiburon
Sep 4, 2015 07:17 PM
Gookiecrunch
Aug 19, 2015 12:00 PM
