6mt Sedan Official Performance numbers?
Old Aug 22, 2003 | 08:48 AM
Riv's Avatar
Riv
Hello all,
Has Infiniti released performance numbers for the 6mt version of the G35 Sedan? I've been looking for a while now and haven't found anything on the 6mt except for MotorTrends "First Drive" numbers of 5.78 0-60 and 14.2(something) 1/4 mile. Anyone know of any other numbers out there for the 6mt Sedan?
thanks,
Riv
Old Aug 22, 2003 | 10:38 AM
3point5SE_Auto's Avatar
Re: 6mt Sedan Official Performance numbers?
mine:
14.457 @ 98.7 at 1700 ft altitude, corrected to 14.2 at sea level
does that help at all?
btw this was on a 95 degree day in phoenix, humidity around 10%
60' of 2.31, no weight reduction, pulled the spare and jack only, ran with an 1/8 of a tank or so on 91 octane shifted at 6800,6500,6300 roughly
Nowhere to go but down 14.0 sounds very reasonable on a cool day for me. 13.9 is likely for those of you at sea level.
I had one run that I trapped at 101 mph but my quarter was only a 14.7. I don't know if it was a mistake or what but I trapped at 101 on the slip
That is a 13.8-13.9 time trap speed.
Better Life thru Chemistry<P ID="edit"><FONT class="small"><EM>Edited by 3point5SE_Auto on 08/22/03 07:49 AM.</EM></FONT></P>
Old Aug 23, 2003 | 02:15 AM
Riv's Avatar
Riv
3point5SE_Auto:
Thanks for the response, I'm guessing by your nickname that you have a Auto Maxima? Those numbers are sweet but I was more looking for 6mt G35 sedan numbers and in particular the official ones from Infiniti, if they have any. I just wanted to know what Infiniti says this car will do.
Thanks,
Riv
Old Aug 24, 2003 | 03:58 PM
Infiniti doesn't say what times the car will do. Motor trend and car and driver say it will do anywhere from 14.1 to 14.5 an you should NEVER magazine race close cars. .3 or .4 seconds can easily be dependent on the driver, tire condition, ecu history, track traction, weather and others. DO NOT COMPARE CARS BASED ON MAGAZINE TIMES!
Actual time below;
Read my profile, I have a 6MT sedan, senor.
those are my stock times
from my nickname, I HAD a 3.5 SE ALTIMA
See link: 300 crank hp http://www.altimas.net/registry/vehi...?vehicleid=225
Better Life thru Chemistry<P ID="edit"><FONT class="small"><EM>Edited by 3point5SE_Auto on 08/24/03 01:01 PM.</EM></FONT></P>
Old Sep 2, 2003 | 10:21 PM
bosssho's Avatar
Every time I read your times 3.5 I wish I had a 6 speed...your 60' times are the same as mine...it's being able to get exactly what you need out of each gear that makes all the damn difference. :-) Now go get that 13.9 in our beloved sedan.
I am practicing this launch with my VDC toggle switched off and I am expecting some mid 14s the next time it's not raining or a 100 up at the track. I am also going to experiment with adding PSI to my rear wheels to get some more slip for a more aggressive launch. A 2.1 60' time for me will be low to mid 14's...for you...high 13's which is insane. Woohoooooo!
John
03.5 G35 14.8 @ 93
02 Maxima SE 14.5 @ 95 (Wife's)
87 Mustang GT 13.2 @ 107
Old Sep 3, 2003 | 12:41 PM
check my alignment post in the sedan section bossho
tiguy99
Mar 1, 2016 11:42 AM
NemesisGee
Aug 11, 2015 07:10 PM
