How's this Craftsman floor jack and jack stand?
Old Feb 20, 2006 | 02:14 AM
  #46
mr_ecktid's Avatar
Can I also use this torque wrench to tighten the bolts needed for the motordyne spacer install? Aren't the 19, 20, etc mm too big though? Where would the smaller ones be?
Oh wait, it's probably universal with the smaller sizes correct?
Old Feb 20, 2006 | 02:21 AM
  #47
Birdhouse's Avatar
It's Lonely At The Bottom
Thumbs up
Originally Posted by mikeee2
Yes. You also need this.
21mm thin wall socket. http://www.tirerack.com/accessories/tools/sockets.jsp
I also bought this http://www.tirerack.com/accessories/tools/pw1.jsp to loosen the wheel nuts instead of the crappy one that Infiniti gives you. This extends and gives you the power to loosen the nuts with EASE.
Hey thanks now we are talking!
-Need Torque Wrench
-Need 21mm thin wall socket
Questions:
Now I already have a lug wrench do I really need this one or is the $8 worth the price?
What brand are these?
Is this the cheapest place to purchase this stuff or was it just convenient for you?
Old Feb 20, 2006 | 12:07 PM
  #48
mikeee2's Avatar
-Need Torque Wrench
Questions:
It was convenient and cheap. Try using the lug wrench to untighten the nuts yourself. If it was over tighten by impact wrench sometimes it takes a hell of an effort to untighten it. I think the gorilla lug wrench is hell worth the $8 bucks. I think even my wife can loosen the wheel nuts with the gorilla lug wrench. Does that answer your question? hehe
If you already have those cross (star) ones at home then maybe you won't need this one. I've used the oem one, star ones and this gorilla lug wrench and this gorilla lug wrench was by far the strongest of them all.
Old Feb 20, 2006 | 06:08 PM
  #49
lelg35's Avatar
From other posts, I've read alot of people bending that metal piece at the jack point. The craftsman jacks looks like a U shape. Without the adapters, I don't see how it can hold the car up in place. Is the jack point the only way to jack up the car?
Yeah, the jack stands are a problem. I couldn't find any adapters to fit those Craftsman jacks that come with the package. And they're such a deep, strange shape. You can raise the car from the crossover section in the front, and the differential in the back. Found this link with a quick search: https://g35driver.com/forums/showthr...highlight=jack. Post #5 has a link to an image showing you the jack points - and, it also shows jack stand adapters for flat-type jack stands. I wasn't able to find these adapters. Hell! If anyone knows where to get them, let us know! I'd pick up a couple in a heartbeat!
Old Feb 20, 2006 | 06:43 PM
  #50
doogie's Avatar
Supporting your car by the diff? That would scare me. I was able to support the rear by some bar-looking things just in front of the rear axles... part of the suspension... I wish I knew what they were called
Old Feb 20, 2006 | 07:12 PM
  #51
skeleton_cru's Avatar
Sedan
Jack points for the sedan...
Attached Thumbnails How's this Craftsman floor jack and jack stand?-jackpoints.jpg
Old Feb 20, 2006 | 08:04 PM
  #52
Birdhouse's Avatar
Arrow
I will take your word for it Mikeee!
I want to find those adapters as well!
Old Feb 21, 2006 | 07:30 AM
  #53
jimmyc13's Avatar
I think the home-made adaptors using a piece of wood with a slit down the middle is an easy, cost effective quick fix (as someone mentioned above).
Old Feb 21, 2006 | 09:35 AM
  #54
Sedan
Here's what I made...
Attached Thumbnails How's this Craftsman floor jack and jack stand?-jack-stand-adapter.jpg   How's this Craftsman floor jack and jack stand?-jack-pad.jpg
Old Feb 21, 2006 | 09:44 AM
  #55
Birdhouse's Avatar
Question
How did you make that? What is that on the right?
Old Feb 21, 2006 | 10:11 AM
  #56
Sedan
I cut the wood adapter from a 2x4 with a coping saw. I then shaped it with a rasp and used double stick foam tape to secure it to the jack stand. The picture on the right is some rubber matting I bought at the hardware store. I cut it into squares and taped them together. I use it on the saddle of my floor jack so it seats correctly on the jacking points.
Old Feb 21, 2006 | 10:31 AM
  #57
Birdhouse's Avatar
Thumbs up
Hey Thanks!
Old Feb 24, 2006 | 04:54 PM
  #58
Birdhouse's Avatar
Question
Hey did you folks use 4 or 2 jack stands for oil changes?
Old Feb 24, 2006 | 05:39 PM
  #59
jimmyc13's Avatar
Why would you need them in the rear?
Old Mar 3, 2006 | 02:05 PM
  #60
Birdhouse's Avatar
Cool
Yay I changed my oil with oil filter, changed my air cabin AC filter, engine air intake filter and rotated my tires!
I saved $200!!! Thanks for the help!
