How's this Craftsman floor jack and jack stand?
Old Mar 6, 2006 | 01:26 PM
  #61
lelg35's Avatar
Originally Posted by Birdhouse
Yay I changed my oil with oil filter, changed my air cabin AC filter, engine air intake filter and rotated my tires!
I saved $200!!! Thanks for the help!
Yeah! If you think about it, those tools probably already paid for themselves in what you saved on cost at the dealership.
Old Mar 7, 2006 | 01:28 PM
  #62
jimmyc13's Avatar
Is the front jack point accessible without removing any of the plastic covers beneath the car up front? I tried to locate it, but not enough clearance to look under there...do I need to drive my car up onto some 2x4's to be able to see the front jack point?
Old Mar 11, 2006 | 05:20 PM
  #63
Birdhouse's Avatar
It's Lonely At The Bottom
I used the car's frame to lift up the car.
Old Mar 11, 2006 | 07:29 PM
  #64
G35_TX's Avatar
I bought this one and love it.
Old Mar 11, 2006 | 07:37 PM
  #65
BigSash's Avatar
TX did you modify the lift pad?
Old Mar 11, 2006 | 07:52 PM
  #66
G35_TX's Avatar
Not at all.
Old Mar 11, 2006 | 07:56 PM
  #67
BigSash's Avatar
are you jacking at the front & rear central points or the reinforced stand points (two on each side)?
Old Mar 11, 2006 | 07:57 PM
  #68
BigSash's Avatar
Also, do you have adapters for your stands?
all these people going on about modifying stands to fit the sill.
Old Mar 11, 2006 | 09:41 PM
  #69
G35_TX's Avatar
When I jacked up my car. I used my large jack to lift the car at the front tie down hooks right behind the front suspension on each side. Very strong location and did perfect. I used that area to jack, then placed the stands under the front part of the frame rails.
Been jacking cars for years without a problem. I just use the strongest parts of the car.
Old Mar 11, 2006 | 09:43 PM
  #70
BigSash's Avatar
next time you jack you should take some pics for us n00bs
  #71
BigSash's Avatar
we are squemish
Old Mar 11, 2006 | 09:50 PM
  #72
G35_TX's Avatar
RGR noob
Old Apr 7, 2006 | 07:29 PM
  #73
mikeee2's Avatar
Birdhouse...I finally opened the craftsman package today...haha
So where did you jack up the car? Did you jack up using the "garage point" area? I peeked down at the car and I can barely see anything. How in the heck do you guys do it.
Old Apr 7, 2006 | 08:54 PM
  #74
MrBig's Avatar
It works on my machine
I have the same jack but I use the jack points in the front center and rear. I cut a small piece of 1/2" plywood to put on the jack pad.
I then put the jack stands under the transverse link (the thing that looks like a lower control arm) in the front. In the rear I put the jack stands under the Rear lower link (the thing that looks like a lower control arm). Never had a problem. I guess I don't trust the jack points at the 4 points under the body of the car.
Old Apr 7, 2006 | 09:01 PM
  #75
jimmyc13's Avatar
Drive your car up onto some 2x4's or larger and then you can see the center jack point when lying beside your car on your back (since you just raised the front end of your car approx. 2 inches. I wondered the same thing, but then figured this out. Good luck! It's easy.
