brembo for sedan?
Old Aug 23, 2003 | 02:48 AM
hksjza70's Avatar
brembo for sedan?
does anybody know if the brembos from the coupe or the Z will fit the sedan? are there bracket issues, line length differences? has anybody tried it?
Old Aug 23, 2003 | 05:28 PM
G35Spot's Avatar
Re: brembo for sedan?
Like mine??
Look here for more https://g35driver.com/rides/detailride.php?cat=&relIdx=18&vehId=182
Frank
CM Motorsports
Irvine, Ca.
Toll Free 866 292 5362
Old Aug 23, 2003 | 08:37 PM
humanRESEARCH's Avatar
Well, you can't get a much better answer than that...LOL
"All the Power in the World resides in the Eyes..."
Old Aug 23, 2003 | 09:25 PM
ryoken's Avatar
Those aren't the Brembos from the Coupe or 350Z.. that's Brembo's aftermarket big brake upgrade for the Sedan.
Old Aug 23, 2003 | 09:40 PM
True, but as long as the wheel has clearance the Z's brake set-up should fit...I recommend the Big Brake Kit simply for the fact that it's 4-Piston at all 4 corners, or you can snap your neck and go for 6-Piston all around...
nismo4090's Avatar
If I wanted to make my brakes better and avoid brake dust without going for a full big brake kit what should I get?
Old Aug 23, 2003 | 09:45 PM
Nismo brake pads are nice from what I understand, as are Alcon...That's one way to get around the dust issue...I suppose you could just throw down the same set-up as the Z, 4-Piston front 2-Piston rear Brembos...
Old Aug 23, 2003 | 10:10 PM
nismo4090's Avatar
i thought they made them only for the Z. Are the g35s brakes the same as the none brembo Zs?
Old Aug 23, 2003 | 10:15 PM
ryoken's Avatar
Other brake pad options for equal/better performance with less dust would be EBC Greenstuff, AXXIS Deluxe/Deluxe Plus, and Hawk HPS Street pads. Haven't tried any yet.
Old Aug 23, 2003 | 10:16 PM
G35Lin's Avatar
Multi-Spoked Mod
i have the wilwoods if you wan to check em out hks! you do live right near me
Old Aug 24, 2003 | 12:12 AM
hksjza70's Avatar
thanks SPOT . . . what did those set you back? close to 3k i'm thinking? The reason I asked, is that I was going to try to pick up a set of the factory's because if it does fit, I know it will fit perfectly and ALL the quirks will be nill . . . I know brembo's reputation, I almost got a set for the supra, but there's something about things coming from the factory for me on this car that I just love . . .
I'm just doin a little research so that the next guy to upgrade his Z or Coupe brembos to a 6 piston or something, I already know if it'll fit or not . . .
Old Aug 24, 2003 | 01:44 AM
Rumble's Avatar
Question:
Are the brake pads on the G35 sedan the same as the ones on the G35 coupe/350z without Brembo's? Therefore, allowing me to purchase 350z brake pads for my sedan.
It's still a G thang!!
Old Aug 24, 2003 | 03:54 AM
deadmanincbh's Avatar
I would think so? Does anyone know the qaulity of the nismo brake pads?
Old Aug 24, 2003 | 01:40 PM
I believe that they are in fact the same pads...There would be no reason I can think of that would have Nissan use separate brake pads on the equivalent Infiniti product...I can't imagine that the Nismo pads are bad are sub-par when compared to any other aftermarket pad
Old Aug 25, 2003 | 09:14 AM
G35Spot's Avatar
The kit retails for $2995. I did a prototype deal with Brembo, so a special deal was done.
The cost for the OEM vs. the real Brembo upgrade kit is near the same, and the Big Red kit that I have is not only larger, but 2.5lbs a corner lighter.
If you have the money to spend, go with the Big Red Brmbo kit, you will not regret it......
BTW, I will have the rears installed this week......
Frank
CM Motorsports
Irvine, Ca.
949 453 1199
