brembo for sedan?
Re: brembo for sedan?
the red ones are the F50 brakes. i emailed brembo and they said they are the best for the G35.
however, i asked them about the 8pot ones that are found on the AMG benz. they said the F50 ones still performed better.
how much more does it cost to replace rotors and pads each time? brembos(big red...) vs. the stock infiniti ones? its a great upgrade...but ill be darned if it doesnt cost a handful more down the road.
hksjza70 (Newbie)
08/22/03 11:48 PM
does anybody know if the brembos from the coupe or the Z will fit the sedan? are there bracket issues, line length differences? has anybody tried it?
__________________________________________________ _
Why hasn't the original question been given a direct answer?
The answer is yes and their's a post on my350Z.com that tell's what part's are involved. Non track Z brakes are the same as the sedan's brakes and the non 6mt coupe brakes. If they use different pad's, that is unknown. But I doubt
they do, even if the part numbers are different as I'm sure they are, I'd be stunned if their compound is different.
Yes their are plenty of good pad's for the stock FRONT brakes, but little to none of them are offered for the rear brakes.
I just tried looking for the post on my350Z.com that tell's you all the parts you need to use to add coupe 6mt brembo's or track 350Z brembos, I can't find it and the bookmark I did of it won't launch. Maybe you'll have better luck.
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
08/22/03 11:48 PM
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
vstypicals
Jul 20, 2015 10:55 PM
