Axis Seven Mod
Feb 21, 2006 | 09:02 PM
Anyone have pics of their sedan with Axis Seven Mod wheels? I am looking at the Silver version for my 2003 Silver Sedan. Also, will a 225/40/18 be to short of a tire? It looks to be about 1" shorter than the 215/55/17 that are standard on my car.
thanks for the help!
Reply 0
Feb 21, 2006 | 09:11 PM
this is the wrong section of the forums. there is a wheels/suspension/brakes section. YOu will get a better response on there. Guys tend to spend most of their time in the same sections... the guys who are into wheels spend their time in the wheels section... the guys into performance spend their time there... you know what i mean
Reply 0
Feb 21, 2006 | 09:19 PM
Quote: Anyone have pics of their sedan with Axis Seven Mod wheels? I am looking at the Silver version for my 2003 Silver Sedan. Also, will a 225/40/18 be to short of a tire? It looks to be about 1" shorter than the 215/55/17 that are standard on my car.
That is a pretty terrible tire size. You should get at least 235/45/18 or something equivalent to your OEM tire size.
Reply 0
Feb 22, 2006 | 12:44 PM
Quote: this is the wrong section of the forums. there is a wheels/suspension/brakes section. YOu will get a better response on there. Guys tend to spend most of their time in the same sections... the guys who are into wheels spend their time in the wheels section... the guys into performance spend their time there... you know what i mean
Not necessarily the "wrong" section....it's general discussion...I started a thread in the wheels section a little while ago (as it pertained to wheels) and it took quite some time to get feedback/response, and it was limited (thread had to do with a tire size fitting/rubbing). Another member posted a similar thread in this section, which also had to do with wheels rubbing....and whaddya know, he received many more responses, much more quickly than I did...my lesson learned.......post up in this section! (unless you're selling something...then yes, that should not be posted here, as the admin's will move your thread & give you the boot! ).
Reply 0
