350z suspension
Old Aug 28, 2003 | 04:54 AM
nuttyprof's Avatar
350z suspension
i want to put the 350z springs and struts on my car, but from what ive read, it lowers the rear more than the front. doesnt make the rear much lower than the front then? since the rear is already lower than the front? also, will the suspension affect the camber of the car like the eibachs. and yes i did do a search. been reading for 2 days straight and found nothing.
Old Aug 28, 2003 | 12:00 PM
Gsedan35's Avatar
Re: 350z suspension
It will lower the front 7/8" and the rear 1 1/8". It does effect the camber. But I don't think this setup will effect the camber as much as the eibachs, cause most eibach use's report getting more than the 1.1" drop eibach claim's. Honestly, I have made no effort to check or correct what my "eyes" see as some neg camber. I fully believe that my car, being that it has the Z33 suspension should be set to the Z camber specs, not the sedan specs. Z specs are more aggressive and more befitting what is now a more sport oriented suspension. I'll take no offence if you disagree with my logic on using Z camber specs vs sedan. Maybe one of these day's I'll run down and have mine checked and done to Z spec's, it's just out of sight out of mind for me I guess.
And just to say it, feel free to drive your setup for awhile and report how you feel. Won't bother me if your own findings don't agree with my own, 2nd opinion's are a good thing.
PS, glad you found a seller so fast.
Ivry 6mt sed
Crawford Pleneum
Injen CAI
22" resonator
Cusco sway bars
350Z springs&struts
Enkei RPM2
Marlin84
Apr 1, 2020 12:52 PM
THMotorsports
Suspension-Vendor
257
Dec 18, 2018 05:43 PM
DRG35R
Jan 31, 2016 07:14 AM
Patrick Bovee
Oct 1, 2015 10:42 AM
