How to bleed clutch?
Old Mar 17, 2006 | 07:30 PM
obender66's Avatar
Anyone has "how to" on how to bleed clutch? It is very simple and effective procedure to improve shifting and I usually bled it along with brakes
Bleed valve is on slave clutch cylinder, but I have no clue where it is located on G. Alldata has no info on bleeding.
Anyone?
Old Mar 17, 2006 | 11:52 PM
jawjaw's Avatar
Make sure to bleed the turn signal fluid as well.
Old Mar 26, 2006 | 10:47 AM
obender66's Avatar
This is very retarded suggestion, since I see no smileys.
Thanks for showing your ignorance.
BTW how many hp did you get from your proudly posted "mods"-clear corners and MTEC bulbs?
Old Mar 26, 2006 | 11:06 AM
boones's Avatar
Anyone?
Here you go:
Old Mar 26, 2006 | 11:58 AM
obender66's Avatar
Thank you very much!
Old Mar 26, 2006 | 01:43 PM
basus's Avatar
Anyone?
What does bleeding clutch mean ? Does it become lighter
Old Mar 26, 2006 | 04:19 PM
boones's Avatar
Same as bleeding the brakes. You do it to get air out of the system. Air should never enter the system in normal operation, but if you have to open the system to replace a part, like the slave cylinder, then you would need to bleed the system afterwards. Bleeding the clutch is usually not part of a regular maintenance routine.
Old Mar 26, 2006 | 11:56 PM
basus's Avatar
Thanks sir
RichardP9
Drivetrain
Oct 26, 2015 11:25 PM
BradMD_96
Oct 6, 2015 09:31 AM
AL8782
Oct 3, 2015 10:26 AM
Jpete
Sep 25, 2015 01:38 PM
yosip1115
Sep 9, 2015 03:30 PM
