Projectors for Sedans
Old Aug 26, 2006 | 08:51 PM
  #31
mrgags's Avatar
wut about 04' or newer Maxima projectors, they have some crazy color to them, those and the TL projectors have the most color output. I personally think those two are some of the best projectors, or S2K projectors
Old Aug 26, 2006 | 09:22 PM
  #32
ttrank's Avatar
Grocery getter
Originally Posted by dofu
Are S2K projectors single or bi-xenon?
They are single.
They have the best cut-off and awesome color. The TSX is the next best single and the TL is the best bi-xenon.
Old Aug 26, 2006 | 09:23 PM
  #33
ttrank's Avatar
Grocery getter
In all my searching I never found anyone who used the Maxima ones. It seems the ones made for Honda seem to be the best.
Old Aug 26, 2006 | 09:32 PM
  #34
E_K's Avatar
E_K
From: Toh-rensa,Ahteesia,Ahcadia,Montree Pak, Longa Beacha
My personal favorite single is LS430. Those things are just crazy wide.
The Maxima ones are E55 bixenons. Good color stock, but you can do better in terms of brightness.
Once you start modifying the projectors, you can get more color and better sharpness than most stock projectors.
Clear lenses are a must.
Old Aug 26, 2006 | 09:39 PM
  #35
ttrank's Avatar
Grocery getter
Ah yes, I forgot about the 430's, those are very nice too!
Old Aug 27, 2006 | 06:19 AM
  #36
chinaman_87's Avatar
Yeah like dofu said its all about the lens. ripples in the lens < Clear lens.
Old Aug 27, 2006 | 12:56 PM
  #37
g35sedan5at's Avatar
can someone please post a pic of a headlight with the quad retrofit done....liek projectors inboth low beam and high beam housing?
Old Aug 27, 2006 | 02:05 PM
  #38
ttrank's Avatar
Grocery getter
I don't believe anyone has done it on a sedan yet. There are quite a few guys with coupes that have them. Just look in the lighting section.
Old Aug 27, 2006 | 04:17 PM
  #39
G35Lin's Avatar
Multi-Spoked Mod
hrmmmm.. soon soon....
Old Aug 27, 2006 | 04:29 PM
  #40
ChiefyMan's Avatar
Go TSX (best value - great color and cut-off without being overly expensive) or S2K (more expensive but about the best cutoff and color avaliable...)
www.customlightz.com < my friend owns that, check it out, he can get you setup with everything and do the labor. He can also do a color mod, which makes it a deeper, brighter blue at the cutoff line. And since we also have HID, you don't need to buy ballasts. Check him out.
Old Aug 27, 2006 | 05:33 PM
  #41
ttrank's Avatar
Grocery getter
Are yours going to be a quad set-up or just the low beams?
Old Aug 27, 2006 | 07:13 PM
  #42
ma_sha1's Avatar
He is doing quad.
There was a quad on sedan a while back done by gdragon, I believe.
This one bellow is another sedan with projector, also done by Gdragon,
But I can't find more photons, can't tell if it's quad.
This is g35xlover's car. hit him up for more photos if you'd like.
I like mine better
Old Aug 27, 2006 | 09:52 PM
  #43
looks liek quad to me..or only the high beam houseing is projector
Old Aug 27, 2006 | 10:04 PM
  #44
ttrank's Avatar
Grocery getter
^+1
It's a quad or he did a bi-xenon on the bottom to use as both.
Old Aug 27, 2006 | 10:51 PM
  #45
yessir.....looks pretty dope and its a new idea, havent thought/seen using projectors on bottom and not on top, ill keep it in mind
jsimonk
Dec 22, 2023 03:49 PM
Jusseth
Sep 13, 2020 12:25 PM
VANST3R
Lights
Jul 27, 2015 08:20 PM
