G35x Brake Squeal - Will Changing Pads Help?
Old Apr 19, 2006 | 01:13 PM
mkrzyzek's Avatar
Wow, so changing all of the brakes to Hawk HPS eliminated the problem for two of you? Maybe I should try that myself. The sound doesn't bother me as much anymore, but i am embarrassed that a $30k+ car makes a noise like that, I think I've scared a couple of people with that noise!
Old Apr 19, 2006 | 05:53 PM
JGFox's Avatar
Thumbs down
+1 I agree completely. Not that I'm self centered but in my business my vehicle says a lot about who I am to my clients (especially since they sometimes ride in it) so the brake squealing is rather embarrassing. I'm sure the brake kit will cost less than getting into a lease on another vehicle... anyone have estimates on cost/installation?
Old Apr 20, 2006 | 12:41 PM
jimmyc13's Avatar
A Brake kit and Hawk pads are two different animals...front Hawk pads you can get for $65 total.......a big brake kit is I believe can range from $2k-$4k. You don't need that to get rid of your squealing. Installation, if you bring it to a shop will probably run you $50-$100 (for the front only)...but that's just a guess. I did it myself using the DIY that member "drewer" posted...never done brakes before, and his DIY made it easy (I was worried doing it, but it was easier than I though).
Old Apr 20, 2006 | 01:26 PM
JGFox's Avatar
ah, then an actual brake kit would cost MORE than getting into a lease on a different vehicle lol... well, say you replace the pads.. does this problem return afterwards?
Old Apr 20, 2006 | 05:22 PM
jimmyc13's Avatar
I think the amt. of brake dust that the OEM pads emits has a lot to do w/ the squealing...but I could be wrong. So I'd say going w/ better pads will eliminate the problem (until of course your pads need replacing because you've worn them down too far).
Old Apr 20, 2006 | 05:45 PM
ckg35's Avatar
Make sure you do a proper bedding procedure on the new pads, which helps a lot with noise and the durability of the pads you install.
Old Apr 22, 2006 | 11:49 AM
decoy's Avatar
My Squeak Came Back
I bought a set of oem caliper stoptech drilled rotors and hawks pads, and about 5 months after installation the rusty sounding squeal came back. I now suspect it is the wear on the clips that hold the caliper and pads in place, so I ordered a $30 kit from Nissan to replace all the clips on my rear brakes.
My scenario may be different b/c my car has been driven in snow and may be a result of rust, but some of you might want to try the cheaper $30 solution first.
wuppiedog
Aug 7, 2015 11:16 AM
kinetek
Aug 3, 2015 04:25 PM
sahizzle110
Jul 29, 2015 11:36 AM
EnCr1pt3d
Jul 29, 2015 03:35 AM
mushu
Jul 15, 2015 03:55 PM
