Question regarding brake fluid level...
Old Apr 9, 2006 | 01:41 AM
mikeee2's Avatar
Hi,
I noticed the brake fluid level is about 1/4 under MAX. I had the same issue probably about 4 - 6 months ago (Don't recall when) but since that time I had refilled it with DOT3 brake fluid. Do you need to use Infiniti/Nissan specifics brake fluids because on the manual it said to use DOT3 or some heavy duty nissan fluid or something of that nature. Now I noticed it's 1/4 under MAX again, is that normal usage or some signs of brake issue?
My car is an 05x with about 9,700 miles. Brakes are fine and doesn't squeak. Couldn't see the front pads but the rear ones are fine.
Thanks...
Old Apr 9, 2006 | 02:59 AM
absolutg's Avatar
workin...
sorry lame qustion but what color is the fluid supposed to be. i looked at mine today and the whole thing looked clear?? i couldn't make out a fluid level but it can't be out of fluid since the brakes are working right?
Old Apr 9, 2006 | 11:32 AM
mikeee2's Avatar
Yes, it's clear. I just wanted to know if it's normal usage for brake fluids because for steering fluids it can go on for years with the same level (at least for my honda it is).
Old Apr 9, 2006 | 12:01 PM
MrBig's Avatar
It works on my machine
As the break pads wear, the less fluid there will be in the reservoir. This is because it is in the break lines and pistons. By no means should you ever fill the fluid to the max line because when you change pads you have to push the pistons back into the caliper, when you do this you push the fluid back into the reservoir. If your reservoir is already full you'll overflow it. Just keep the fluid lever somewhere in the middle between the min and max lines, like what you do for the engine oil level.
The fluid should be clear to a very light yellowish color. The longer it's in there the darker is becomes because of use.
Old Apr 9, 2006 | 12:11 PM
mikeee2's Avatar
Thanks again Mr. Big
Old Apr 9, 2006 | 12:28 PM
MrBig's Avatar
10 yrs. as a mechanic and you tend to pickup a few things.
Old Apr 9, 2006 | 12:36 PM
mikeee2's Avatar
No wonder I wish I am as technical as some of you guys...
laksjd84
Feb 28, 2026 01:58 PM
bu villain
Accessories
63
Aug 25, 2016 07:14 PM
G35Sask
Intake & Exhaust
16
Aug 5, 2015 10:17 PM
kinetek
Aug 3, 2015 04:25 PM
mushu
Jul 15, 2015 03:55 PM
