Will this wheel\tire setup work?
Old Apr 11, 2006 | 01:29 AM
oviwon's Avatar
First post and new to this site. Got an 04 or maybe a 03.5?
I am looking at getting some TSW-Exclusive 20x9s on the front and back with Pirelli Pzero 245/35/20. I am also wanting to drop it an inch with the 350 spring deal.
Do I keep the same setup on front and back or do I need to stagger it? Not sure on staggering or offsetting.
Any help or links appreciated!
Attached Thumbnails Will this wheel\tire setup work?-p1060680.jpg   Will this wheel\tire setup work?-p1060683.jpg
Old Apr 11, 2006 | 01:44 AM
dyenboy's Avatar
Registered
welcome to the site..
there is a discussion already about 20's, here it is
https://g35driver.com/forums/g35-sedan-v35-2003-06/90540-staggerd-set-up-questions-sedan.html
Old Apr 11, 2006 | 02:53 AM
skeleton_cru's Avatar
Sedan
A 9" wide wheel won't fit in the front. If you want to keep the same size, front/back go with 8.5". You can run a staggered set-up, 8.5 front / 9.5 rear is the standard, but don't expect a big fat lip in the rear.
Old Apr 11, 2006 | 05:09 PM
oviwon's Avatar
In that case I think I will go 19x8.5 offset 35 all around. Would it be alright without the staggering? What would the tire sizes need to be to line up alright?
Old Apr 11, 2006 | 06:42 PM
Sedan
Non staggered is fine, it's what the sedan was designed for. 245/40 or 245/35 tires.
Old Apr 11, 2006 | 10:15 PM
oviwon's Avatar
Thanks Skel!
One last thing is how will this effect the ride? Should I expect to feel every crack in the road now? Stock already seems to be a little hard. Would the 350 springs make for a softer or harder feel?
Old Apr 11, 2006 | 10:32 PM
codeflux's Avatar
wider tires - more tire noise. looks don't come cheap, you know.
btw, it's not "Skel", it's "Cru".
perfect fitment would be: 8.5" +43 offset front, 9.5" +43 offset rear. yes, any wheel diameter - 17 to 20. if you put anything over 20 on that car, we will all taunt you non-stop.
Old Apr 12, 2006 | 01:06 AM
Sedan
Thanks Skel!
Yes, the ride will be rougher, the 350 springs won't help.
Sedan
911Turbo
19 Inch
Aug 24, 2016 08:31 AM
Popes
Jul 29, 2015 05:07 PM
realtalk21
Jul 20, 2015 09:07 AM
carid
Wheels & Tires-Vendor
Jul 20, 2015 08:57 AM
