Replacing studs
Old Apr 11, 2006 | 08:20 PM
VQ Hotness's Avatar
Replacing studs
Does anyone no if the process of replacing your studs is difficult.If not How do you do this?Do you need any special tools?
Thanks
Old Apr 11, 2006 | 09:42 PM
RetAF's Avatar
Talking
I have my wife convinced that HER stud cannot be replaced. So far, so good!
Assume you are talking about wheel studs. We used to use two nuts, tightened against each other if the stud was threadded in. Some are pressed in, and sometimes, you can remove them from the back side of the hub. Hopefully, one of the Infiniti techs will let us know.
Old Apr 11, 2006 | 11:21 PM
VQ Hotness's Avatar
Yes, wheel studs Thanks.
Old Apr 12, 2006 | 12:30 AM
Texan1's Avatar
Q50 Red Sport 400 RWD
Thanks
gay bar
maybe
sorry to not contribute to this thread, but could not resist.
Old Apr 12, 2006 | 01:37 AM
Gsedan35's Avatar
Thanks
The bolts for the brake caliper to the suspension upright are 22mm
The bolts for brake caliper itself are 14mm
I just did mine in the front.
This is how I did it.
Remove brake caliper from suspension arm
Remove disk brake (left disk needed a lot of umm encourgement it was sort of rust seized on)
Hammer out oem studs
My 10mm studs would not go into the oem holes from behind because of their greater length and because of the dust sheild. I noticed a couple of spots where I could grind away on the dust sheild and make the clearance I needed so I did.
With the 5 studs just sitting in the hub I put the disk brake on temporarely (pain because the studs kept on wanting to push back). Then I put on spacer on and used tightened lug nuts on to pull the new studs into the back of the hub. Another way to do this would be to use open ended lug nuts so you don't have to fuss with putting the disk brake on to pull the studs into the hub.
Reassemble and repeat on the other side.
Old Apr 12, 2006 | 04:25 PM
VQ Hotness's Avatar
Thanks...
Old Apr 12, 2006 | 04:42 PM
VQ Hotness's Avatar
Are the rotors sposed to shake a little.. Are they attached to anything??
Old Apr 12, 2006 | 10:33 PM
louielou's Avatar
This is not the G, but it should be too much different.
http://forums.evolutionm.net/showthread.php?t=150266
Old Dec 29, 2006 | 01:37 PM
Nate99's Avatar
Bumping up an old thread. I changed the brake pads this morning on my wife's G only to find out that the goobers at the tire shop cross threaded one of the lugnuts (which has since liberated itself from the stud altogether for a life of freedom on the open road, or beside it anyway) and totally ruined the threads.
I pulled the brake caliper mouning braket off, and tried to remove the rotor, but I guess I didn't use enough persuasion. I was not sure if there was something else retaining the rotor to the hub, so I didn't want to force it.
Has anyone else here removed a stud using the BFH approach?
Old Dec 29, 2006 | 05:16 PM
Nate99's Avatar
Just an update, I got a new stud at the local Nissan dealer (part # 43222-70T00, about $4 each) Whacked the old one out with one good shot from a 3 lb. hammer and pulled in the other with an open nut from the hardware store. The rotor came loose with one tap from a rubber mallet.
Old Dec 29, 2006 | 05:21 PM
marcelkatz's Avatar
whats a stud?
Old Dec 29, 2006 | 05:25 PM
ttrank's Avatar
Grocery getter
Originally Posted by marcelkatz
whats a stud?
This might help.
http://www.boltscience.com/pages/failure4.htm
wuppiedog
Engine - Exhaust
Sep 6, 2015 12:07 PM
netcbc
Wheels & Tires CDN
Aug 25, 2015 09:42 AM
miata007
Aug 17, 2015 04:36 PM
laksjd84
Steering & Suspension
14
Aug 8, 2015 11:47 AM
si_driver
Jul 14, 2015 12:29 PM
