Synthetic oil vs. Regular oil
Old 09-12-2003, 06:53 PM
GSGNG35's Avatar
Re: Synthetic oil vs. Regular oil
It does! Here's a pic of mine, all original
2003.5 G35 6MT Black/Graphite Prem/Aero/Winter
1987 GN Intercooled SFI Turbo (22K original miles)
1970 GS 455 Stage 1 4-Speed (#'s matching)
Old 09-12-2003, 06:58 PM
GSGNG35's Avatar
And it's motor
Old 09-12-2003, 07:17 PM
DaveO's Avatar
GSGNG35,
WOW! On a cool morning, quicker than a 425Hp big block Vette!
Want to sell?
DaveO
Old 09-13-2003, 09:36 PM
GSGNG35's Avatar
DaveO,
Thanks
On a COLD morning 0 - 60 4.9 sec! Only being homeless would cause me to sell :-). Here's my other ride.
70 Gran Sport 455 Stage 1 510lbs torque!
Old 09-15-2003, 03:52 PM
dspisak's Avatar
Hi, chinee. I spoke today with my contact, a ChevronTexaco motor lubes specialist. Due to proprietary and legal reasons he would not reveal a specific finished product. What he did say is that ChevronTexaco tests its lube technologies and formulations far in excess of engine manufacturer's OEM requirements.
The G35 Owner's Manual, states "Only those engine oils with the American Petroleum Institute (API) certification mark on the front of the container should be used. . . . If you cannot find engine oil with the API certification mark, use an API grade SG/SH, Energy Conserving I & II or API grade SJ or SL, Energy conserving oil. . . ."
Because of my driving habits I can apply the Schedule 2 change interval of 7,500 miles. Also, the ambient temperature in my area seldom drops below 32F (0C). Thus, I plan to use ChevronTexaco's Supreme 10W-30 (which meets API SL, Energy Conserving for API SL, and ILSAC GF-3) at 7,500 mile change intervals.
<font color=blue>Dan</font color=blue>
Old 09-15-2003, 04:11 PM
SixFive's Avatar
Is that the stock air tube on the GN. That sure is a different compartment than the 1982 regal 3.8 I had. That car sucked but was a great ride for a few years in college. Great interior for a used old car..i had the royal blue with the cushion top upholstery and the radio stuck on one station for 3 of 4 years. My bud with the GN has a 96 vette with mods and it will never come close to GN times.
How does the GN run at high speed - is it rigid and solid to handle??
Old 09-15-2003, 05:28 PM
chinee's Avatar
Thanks Dan... I'm going to try running my ODI to 10K with the Mobil1. If that works...that'll be my interval for the next year or two. I just viewed some pics of a 1995 Camry V6 engineat 110K miles that has run M1 since 3K... engine looks very clean... see here for pics:
http://theoildrop.server101.com/ubb/...c;f=1;t=003534
Now he changed every 3-5K, more often than I plan to, but 110K with no varnish... that's great performance!
<font color=red>chinee</font color=red>
2003.5 G35s
Old 09-15-2003, 08:19 PM
DaveO's Avatar
GSGNG35,
Wow! One more time!
DaveO
Old 09-15-2003, 10:18 PM
GSGNG35's Avatar
Sorry to moderator that this got a little off topic...
Everything you see is stock configuration except for stock pieces that were chromed. The 3.8 received a MAJOR revamp in 86 and 87 when the turbo was moved to the front and the intercooler was added. The car has constant acceleration and is stable until the limiter kicks in at 126 MPH. This limit was set because of factory delivered tires and aerodynamics. Of course I have seen them run in the area of 200 mph at the track! Mine is stock so it runs high 13s at about 102 in the 1/4 with A/C and loaded with options.
Old 09-15-2003, 10:54 PM
dspisak's Avatar
Chinee, yes, the engine in the pics appears to be very clean. It reminds me of my various Audi and VW motors after 80,000 to 115,000 miles on conventional oils. Don't get me wrong. I'm not saying that conventional oils are as good as synthetic. I'm only saying that conventional oils are completely adequate for street motors. I find it hard to justify the five to ten times cost premium for synthetics.
Recently, the machine shop at work received a diesel truck transmission (Kenworth or Peterbuilt) to clean for display purposes. This transmission went 500,000 miles on the original oil fill and showed essentially no wear. I don't know if the oil was conventional or synthetic. But, 500,000 miles on the original fill is pretty good going.
Old 09-16-2003, 08:19 AM
chinee's Avatar
Dan...this is not good... you're raising doubts in my mind as to whether I should continue with synth or not.
However since the advantage I'm looking for is a longer oil drain interval (just for convenience) I think I'll stick with the M1. If I was only driving 15-18K/yr on each vehicle though, I would switch back to dino... the top three (based on feedback I've read) being Chevron Supreme, Pennzoil and GTX, not necessarily in that order.
Time for me to get a life!
2003.5 G35s
Old 09-16-2003, 09:11 AM
04NismoV35's Avatar
GSGNG35, one question.
I have a friend that's into American muscle classics like the two you've shown. He's also the type of guy that went for pure GM and nothing else. What made you get a G35 instead of some American sports sedan.
Just wondering.
Old 09-16-2003, 11:49 AM
khsonic03's Avatar
What is the best dino oil? I have heard that Valvoline is the best, if not one of the best.
'03.5 Brilliant Silver Sedan
Premium, Aero Kit/Package, Sport, Winter
Stillen Air Box, Clear Corners, Alum Pedals
  #30
Old 09-16-2003, 04:20 PM
dspisak's Avatar
Yes, I used to spend hours worrying about which oil to use. I settled on the manufacturers' recommendations. My wife's BMW uses BMW synthetic, their version of Syntec, which is the recommended oil. My G35 has a fill of BMW synthetic because I bought a case at $3.80/qt from the local BMW dealer and I thought I'd try it in the G. I also have a case of Chevron Supreme for my son's Passat. When the G35 need an oil change I'll use the Supreme.
Quick Reply: Synthetic oil vs. Regular oil
