350z sways with suspension on sedan.
Old Apr 18, 2006 | 09:39 PM
Mr.Igor's Avatar
I am going to get 350z shocks and springs, question is should I get the 350z sways also? I have 2003.5 NON-Sport. If i get them, would it make a difference?
Old Apr 18, 2006 | 11:30 PM
Mr.Igor's Avatar
no one
Old Apr 19, 2006 | 12:05 AM
godmans's Avatar
I think they have the same sways
while the 05+ coupes and Z have upgraded stiffer sways
Old Apr 19, 2006 | 12:38 AM
Mr.Igor's Avatar
you sure?
Old Apr 19, 2006 | 01:24 AM
godmans's Avatar
90% sure =)
and also you can see that there are barely any ppl changing out their sways with the 03/04 Z sways...
Old Apr 19, 2006 | 12:52 PM
Mr.Igor's Avatar
I have a chance to get a set of 2005 oem gt zr springs, thats the roadster i guess. What kind of shocks do i need to run this setup? and how would this setup work on my sedan? What kind of drop etc..
Old Apr 19, 2006 | 01:48 PM
godmans's Avatar
well
If you do have stock "sport" shocks, you can go with the 05 Z springs; with that setup, you should be expecting around 0.9" drop in the front and around
1" drop at the back.
However, if you are being picky on your ride quality and the performance, you can go with either the 05+ coupe or Z shocks that have revised valving to accomodate the increased spring rate at the back.. OR you can choose to go with the D-spec shocks from Tokico or the Koni shocks.
Yet, if you don't have the sport shocks (sport shocks are red..), I would recommend you either get some stock sport shocks or just go with the above two options!
Good luck with the drop
Old Apr 19, 2006 | 01:52 PM
Mr.Igor's Avatar
Originally Posted by godmans
well
Hmmm... i am going to get 05 - 06 Z shocks too... But 0.9" drop in the front and around 1" drop at the back, would be bad... The back is sitting much lower now, I dont have the sport pack. 1" drop with the SPORT pack, and how much of a drop from the NON sport suspension?
Old Apr 19, 2006 | 01:58 PM
Mr.Igor's Avatar
Another question i have is if i go with 03 Unrevised full suspension, the ride will be bouncy? and sag more? so 05+ is the only way to go correct?
Old Apr 19, 2006 | 02:51 PM
some.devil's Avatar
I hear it's only the o3 shocks that are bouncy
Old Apr 19, 2006 | 07:27 PM
Mr.Igor's Avatar
i wish i can do front 1.2" and rear 1" that would be perfect i think. i just want to spend as less as i can.
rezendvous420
May 31, 2020 01:26 PM
StreetStandard
Suspension-Vendor
Jan 18, 2016 03:36 PM
NohoG35revup
Aug 22, 2015 12:13 PM
linedr89
Aug 17, 2015 05:11 PM
netcbc
Steering & Suspension CDN
Jul 24, 2015 11:25 AM
