Quick pic of the G w/ coupe 19s.
Old Apr 26, 2006 | 12:12 AM
Jeff92se's Avatar
Red Card Crew
It already looks low in the rear. Odd. Took me awhile to put the wheels on because I swapped front pads to Axxis Deluxe. No way I was going to clean the stock brake pad dust off of these things.
Old Apr 26, 2006 | 12:13 AM
UgOtSmOkEdOrC's Avatar
nice......all u need is a drop
Old Apr 26, 2006 | 12:22 AM
g35guy86's Avatar
looks good, tire shine is nice also
Old Apr 26, 2006 | 12:46 AM
Andy2434's Avatar
Looks great . . . I like the look.
Old Apr 26, 2006 | 12:54 AM
GLuXuRy's Avatar
looks good !!!
Old Apr 26, 2006 | 08:35 AM
blancmax's Avatar
Excellent choice! I have the 18 inch version, but I wouldn't mind having those instead. Is the car lowered and how long did it take you to change the pads?
Old Apr 26, 2006 | 11:11 AM
afr0puff's Avatar
Supa Dupa Moderator
Very nice!
Old Apr 26, 2006 | 11:50 AM
Jeff92se's Avatar
Red Card Crew
Not lowered at all but plan on getting the Z springs. Pads couldn't be easier. Rotors were in good shape so it was just a matter of loosening the two caliper bolts, removing the bottom one, sliding the caliper up, replacing pads, shims, cleaning the clips the pads ride in, pushing the caliper piston back and and sliding the caliper back down onto the torque member and torquing down the bolts. Maybe 30-40 min.
Old Apr 26, 2006 | 12:40 PM
JEVERYDAY's Avatar
lookin pretty good
Old Apr 27, 2006 | 05:28 PM
trey.hutcheson's Avatar
Looking good Jeff.
Old Apr 27, 2006 | 05:35 PM
Jeff92se's Avatar
Red Card Crew
Thanks. Just for reference, I've tried to get the weight information. Roughly 50lbs each for the Coupe 19s. 29lbs = tires 20lbs=wheels.
VS stock 17s. Some said the stockers were near 24lbs. Stock EL42s in 215-55-15s come in at around 25lb. For a total near 49lbs.
All these figures are probably +/- 1-3 lbs though. But for a plus 2 upgrade, this is not bad weight wise
Old Apr 27, 2006 | 10:14 PM
Loe G35's Avatar
My 6spokers and 5spokers came to about 22lbs (17X7" rims) when I weighed them a month ago. 20lbs for a 19" rim is extremely light for an OEM wheel. Good choice, it looks great!
Old Apr 27, 2006 | 10:34 PM
DaveB's Avatar
Looks real good. The 350Z springs will look great. I hope the rears do clear with the drop because the car will look sick. Especially if you paint the lower sills.
Old Apr 28, 2006 | 02:45 PM
Jeff92se's Avatar
Red Card Crew
I think I'm going to try your combo Dave. Z fronts and Coupe rears. I'm getting complete sets of both so I can try diff setups if I wish. Also getting some coupe shocks. I think I'll like the mild spring/shock rate upgrade.
Old Apr 28, 2006 | 02:55 PM
blancmax's Avatar
Are you going to swap the springs yourself? Also, do you have to swap the shocks or is it just recommended? I had the H&R - KYB/AGX combo set fairly stiff on the Maxima. My 06 Sedan has the sport tuned suspension and I was curious if it can be lowered without swapping the shocks.
Thanks
