How long did the Stock Turanza EL42's last?
Old May 2, 2006 | 11:02 AM
Spartus's Avatar
so the 235/50/17 tire as an upgrade to the 215/55/17 tire won't reduce gas mileage and acceleration?
Old May 2, 2006 | 12:05 PM
DaveB's Avatar
Generally a 235/50R17 tire when mounted on a 7" wide rim is about .2 to .4" taller, .6 to .7" wider, and 2 to 3lbs heaveir than a 215/55R17. The increased width will result in a bit more drag and the weight could slightly impact MPG. I think all of that would be pretty minimal though. The reason I'm not going with 235/50R17 is because of the tire bulge I see which tends to hurt initial steering response.
Old May 2, 2006 | 12:15 PM
Jeff92se's Avatar
Red Card Crew
use this to calculate your overall tire diameter vs stock. You can even enter multiple tire sizes vs stock. But be careful. Tire makers do have limitations on what size rim is recommended for a particular tire size. tirerack has alot of specs on this
http://www.miata.net/garage/tirecalc.html
Old May 2, 2006 | 01:21 PM
jimmyc13's Avatar
Originally Posted by ABQ_G35
When I traded my '04 in for my '05, the Turanza's had almost 19 k on them, and they still had plenty of tread left, not even half worn, I'm guessing at that rate, could have gotten at least 40k out of them. I never found them to be a bad handling tire at all, even in wet weather.
I feel the same way about them..not sure how people drive to only get 15K outta them...maybe a lot of City driving?
Anyways, in case anyone is interested, I'm looking to get rid of my tires (only tires), now that I have a 19" summer setup. The price is definitely negotiable:
https://g35driver.com/forums/archived-sales/95695-feeler-17-oem-turanza-s-tires-only.html
Old May 2, 2006 | 01:35 PM
InTgr8r's Avatar
Staff ALUMNI (retired)
LOL... Mine lasted ~500 km (310 miles)
.........Until I got into the shop to replace them.
I did however find something they're good for.....
holding down the winter cover on my pool steps.
Old May 2, 2006 | 05:48 PM
jimmyc13's Avatar
In that case, do you need any more winter pool cover holder downers?
Old May 2, 2006 | 06:02 PM
Endless G's Avatar
LMAO Ian!!!! At least they are some use!!!
Old May 3, 2006 | 10:18 PM
lieb923's Avatar
Exclamation Tires
Goodyear F-1 has a 235 -50- 17. Tire rack says the are a plus 0 replacement. Great reviews.
Jiggerjuice
Oct 5, 2015 02:33 PM
tiguy99
Jul 26, 2015 01:39 PM
RA102223
Intake & Exhaust
Jul 25, 2015 01:03 PM
realtalk21
Jul 20, 2015 09:07 AM
