Z-Tube
Old May 12, 2006 | 04:57 PM
Neal376's Avatar
what!?!?!?!? how can you not notice the increase of induction noise w/ the Z tube! I noticed it right away! SCREAMS above 4k my passengers noticed it too!
Old Jun 8, 2006 | 05:12 PM
flnsx's Avatar
Neal,
Do you have a K&N too or JUST the Ztube?
Old Jun 8, 2006 | 05:17 PM
LuXXXz's Avatar
how much doez a ztube and k&n drop in run around???
Old Jun 8, 2006 | 07:25 PM
Neal376's Avatar
i had them both
Old Jun 8, 2006 | 07:31 PM
Msedanman's Avatar
O.F. Administrator
Originally Posted by shredX
I respectfully disagree.
As you can see, I have the Z tube + K&N drop in. I did them both at the same time & feel the engine sounds much better under load. Just after 3k rpm it sounds a little deeper & a lot nastier.
Just realize that there is little to no HP gains & you won't notice a thing until you get up there in the rpm's.
(I have the MD 5/16 spacer sitting in my garage waiting for the weekend. It should sound even better by Sat afternoon.)
Klubbheads: Maybe you can't hear the difference of the engine b/c of your custom exhaust?
I ended up with the same setup (Z-tube & K&N drop-in) on my Coupe and liked it.
C.
Old Jun 8, 2006 | 07:37 PM
maj83's Avatar
lazy a$$
So ummm...you guys won't notice the induction noise without putting the K&N drop in filter? Because I installed the Ztube + K&Ndrop-in at the same time...very nice sound. I'm just wondering why it would be differerent from the stock filter...
Old Jun 8, 2006 | 09:02 PM
mackinnr's Avatar
$100 or so, check out everythingg35.com, I think they sell it as a combo pack.
I'd say it's worth every penny, induction noice is greatly increased with Z tube and K&N. Dropped in the MD spacer 2 weeks ago now the intake note is slightly deeper and louder, and the car pulls at little harder from 3-6K RPM. Nothing spectacular, but worth the $300 or so all together
Old Jun 29, 2006 | 08:44 PM
Calvin's Avatar
Overglorified Altima
picked mine up today for $115 from a nissan dealer.. 75 for ztube and 40 for k&n
Old Jun 29, 2006 | 09:15 PM
Lip's Avatar
Lip
Thought I'd add my two cents
You will hear the difference. It is significantly louder with the Z-Tube than with the stock baffled intake tube. Under normal throttle, there may be very little difference- As others have said above 3-4k it's quite a bit louder.
By the way, I have the stock paper filter. I've had K&Ns on every other car I've owned, said screw it this time around. Actually just replaced the paper filter too.
Old Jul 1, 2006 | 06:21 AM
G35HAWAII's Avatar
Did my Z-Tube and K&N Drop in together, too me it sounded a little louder and raspier only above 3k. Added the Stillen Gen 2, as one would expect it got much louder and a little deeper. Recently added the MD 5/16" Iso Spacer, IMO it added a little volume but made it even deeper sounding (not to mention adding to the Butt Dyno). I don't regret adding any of the above mentioned mods.
Old Jul 7, 2006 | 02:15 AM
jimgpark's Avatar
Seriously, and respectfully, I don't understand how ppl can say they don't hear any difference from the z-tube being added.
I just put it in today (i already had a K&N in) and immediately noticed the whistle noise while revving. Then I asked my gf to go with me for a quick 10 minute test run. For most of the run, I decided the whistle was a bit annoying but amusing at the same time. Other than that, I could hear a deeper, throaty but mild discernable difference over 3K (not at WOT), but barely noticeable with the windows up.
Near the end of the run, I gunned it a few times, in city traffic and then getting on the freeway, WOT. This thing is damn loud for such a simple bolt on mod. My gf doesn't know much about cars, but she was saying "it sounds totally different. it sounds louder and meaner." I totally agree with her. If anything, I wasn't expecting the car to be that much louder from a simple mod. I guess the resonator on the g35 tube makes that much of a difference. In any case, I'm going to keep the z-tube on for now. I like the fact that it's not very noticeable unless you're at WOT. But in fact, near the end of the run, the noise was definitely louder than at the beginning of the run. Perhaps it was the ECU adjusting, I can't be sure.
Old Jul 7, 2006 | 02:40 AM
RocketG35's Avatar
Why do I bother to DIY???
I just put it in today (i already had a K&N in) and immediately noticed the whistle noise while revving....
I hear a "whistle" noise too around 3k...I thought I was getting some type of "leak" in the exhaust (feared a leak in the mid pipe install), but several people said they can hear the whistle coming from the z tube/k&N area (tested this while gunning it in neutral w/ the hood open). My friends like the sound (said its like a pseudo turbo blow-off).
I'm not too sure if I like the whistle sound...its a bit annoying at times.
Old Jul 7, 2006 | 02:59 AM
jimgpark's Avatar
Yeah, I actually thought I had a leak in the 3/4" mid-pipe coming out of the tube. I got confused from the DIY instructions because the picture attachments weren't hosted anymore. I started yanking out the mid-pipe area while it was still clamped, thinking that I had already completed that step. I yanked it out about a 1/2" from the other rubber hose it was attached to and spent a good amount of time stuffing it back in to make sure there wouldn't be any leaks.
My pliers I was using were too small to unclamp the mid-pipe but luckily I found a large rusty plier/wrench tool the allowed me to loosen the clamp. That was the hardest part for me. Btw, this was my first DIY ever and I was racing against the sun going down. I was pretty proud for having got it done in under 30 minutes. Although I have experience building PCs and such, I'm not exactly mechanically inclined. Maybe this will be a start for me. I went to Home Depot today to get the socket wrenches so I could specifically do it myself. Anyhow, yeah, I almost feel like a poser masquerading as if I had a turbo and blow-off valve with the whistle and all. Is it all worth it for 1-2hp? Hopefully it will complement my future mods.
Anyhow, yeah, the whistle is definitely from the z-tube. I'm almost positive I had everything clamped down tight and in place. I wonder where that whistle is coming from?
Old Jul 7, 2006 | 10:22 AM
flnsx's Avatar
OK guys,
The whistle will go away and you will still have the deep intake noise if you put your stock air filter back in. I think it's the best of both worlds. No intake whistle but a nice deep growl on full throttle runs.
The whistle comes from the butterfly valve being partly opened in the throttle body. It is the air rushing past it.
Take care
www.automoleskin.com
Old Jul 7, 2006 | 11:26 AM
  #30
da mayor's Avatar
you can hear neal's stillen intake and z-tube on the highway doing 80mph. it sounds just like my altima v6 nice and loud intake sound
