New 2007 G pics from Lennox, MA
Old Aug 21, 2006 | 02:18 PM
Garnet Canuck's Avatar
Traveling Administrator
Originally Posted by elyk
As for front bumper, I like the LS blue over the red one, what do you guys think?
I do as well.
Old Aug 21, 2006 | 02:26 PM
tkman00's Avatar
it's good to see there will be a 6mt in the first MY
1stG35inCTRY's Avatar
LOVE the beige interior with wood !!!!
Old Aug 21, 2006 | 03:05 PM
Speedoholic's Avatar
G (enie) FUNK ERA
Originally Posted by luxman
This is my favorite shot that shows the new lines on hood and around the front wheel panels, very sexy and muscular. It also shows the new integrated fog lights on the inside of new headlight. I prefer bottom separate fog lights but no big deal.
+1
SEXY MAMA!
MikeyMike's Avatar
Rollin On Dubz
interesting shots...I'd love to drive one of these and see if it's any different from the current gen G's
Old Aug 21, 2006 | 03:14 PM
Sportcoupe35's Avatar
great pictures!!! That dark color must be the new silver graphite
Old Aug 21, 2006 | 03:20 PM
trey.hutcheson's Avatar
Did you happen to notice/write down the tire sizes?
Old Aug 21, 2006 | 03:33 PM
Trey, the tire sizes are;
225/55 VR17 All Seasons for the regular G35
G35 with Sport Package has 225/50 WR18 Front Summer Performance Tires and 245/45/WR Rear Summer Performance Tires.
Old Aug 21, 2006 | 04:03 PM
That means that the stock tires(17's) are 26.7 inches tall, which is 4 tenth of an inch taller than the current sedan.
The 225/50/18 fronts measure 26.9 inches(even taller), whereas the 245/45/18's are 26.7 inches tall. So the overall gearing is a bit taller. That also means that with the sports tires, the front are 2 tenths taller than the rear. I wonder if that's visually apparent in person.
Do you have the gear ratios and final drive ratios?
Old Aug 21, 2006 | 04:16 PM
07G's Avatar
07G
Thanks for the pictures!
Old Aug 21, 2006 | 04:19 PM
Ask and you shall receive. Here is what I have.
Compression Ratio: 10.3:1
Horsepower: 306@6800 RPM
Torque: 270ft-lb@5200 RPM
Gear Ratios
5AT 6MT
1st 3.841 3.794
2nd 2.352 2.324
3rd 1.529 1.624
4th 1.000 1.271
5th 0.839 1.000
6th --- 0.794
Final Drive 3.692 3.692
Old Aug 21, 2006 | 04:20 PM
mark5's Avatar
check out that air duct on the lower drivers side
Old Aug 21, 2006 | 04:30 PM
Jeff Flowerday's Avatar
I don't think that's an air duct, more than likely the radar unit for the Intelligent Cruise Control.
Old Aug 21, 2006 | 04:32 PM
ma_sha1's Avatar
This must be the new "Ram Air" intake they told the press about, responable for several HP gains. Need to ge one of this into my 05 sedan
Old Aug 21, 2006 | 04:48 PM
  #30
Gear Ratios
5AT 6MT
1st 3.841 3.794
2nd 2.352 2.324
3rd 1.529 1.624
4th 1.000 1.271
5th 0.839 1.000
6th --- 0.794
Good info to have. So both models now share the same final drive? I find that interesting. I also find it interesting that the final drive is even shorter. That will help acceleration. Not a ton, but every little bit counts.
That means that with a redline of 7500, a sports model equipped with 245/45/18's will have the following top speeds:
Gear - 5AT - 6MT
1 - 42 - 42.5
2 - 68.5 - 69.4
3 - 105.5 - 99.3
4 - 161.3 - 126.9
5 - 192.2 - 161.3
6 - NA - 203.1
That means that both models will be geared to reach 190mph, and the 6mt will be geared to exceed 200mph. Interesting.
