Horsepower: (New standard vs. Old)
Old Sep 8, 2006 | 10:20 AM
Gavine's Avatar
I've learned on this forum that there's a new standard for measuring horsepower which is more stringent. The 2007 G35, as I understand is rated at 306HP under this new scheme.
I'm curious as to what the rating would be under the old scheme. Is there a conversion formula or is it much more complicated than that?
The Acura RL was listed at 300hp and now they're saying it's 280hp. Does that mean that the G35 would be more like 320hp under the old scheme?
Old Sep 8, 2006 | 10:33 AM
kraqcommando's Avatar
The old "SAE horsepower" is no longer used because it gave a misleading number due to the fact that an engine was tested without any auxillary items installed like alternators, air cleaners or fans. "SAE net horsepower" is used to indicate the engine was tested with everything in place.
Google....know about it, tell a friend
Old Sep 8, 2006 | 01:41 PM
terryw's Avatar
the rev up 298hp engine makes 293hp in the new scheme and 280hp engine makes 275hp under the new scheme. both loss 5 hp, nissan didnt overate the engine nearly as bad as toyota and honda.
Old Sep 8, 2006 | 02:39 PM
gspotter's Avatar
+ 1
Old Sep 8, 2006 | 02:41 PM
depends on the cars really
Old Sep 8, 2006 | 06:47 PM
Lip's Avatar
Lip
Is that true though? I though the "old" method, or what is now described as Gross HP rating you described was changed out years ago-
I have a hard time believing that a adding alternator, AC, Power Steering, smog pump, and air cleaners would only cause a net drop of 5hp on the dyno.
Old Sep 8, 2006 | 06:54 PM
asianautica's Avatar
Not all cars drop in power. The TSX and C6 Z06 for example gained 5HP from the new SAE standard. So, there's no real conversion calculation.
RemmyZero
V36 DIY
Apr 23, 2018 11:13 AM
stratous01
Oct 7, 2015 10:19 AM
onlyhuman
Engine - Electrical
Sep 21, 2015 12:28 PM
TNRocker
Sep 21, 2015 08:36 AM
