Can somebody explain the compact flash card system in the 2007 G?
1) Does a blank CF card come with the car?...or is the idea you just buy as many as you like.
2) What memory formats are accepted by the CF slot in the car?
3) What is the maximum capacity of the card ( ie how many songs can it hold!)
4) How do you 'play' or activate the songs on the card?....ie is there a button on the nav display for flash card??? It's not radio, or disc or aux...so which button do you press!!!
5) Can you shuffle, skip, reverse etc????
2 - If your card can work with a CF-adapter (for eg SD to CF), then it work in the car (as long as it is using FAT16/FAT32)
3 - dunno
4 - Push Disc/Aux button till u get to CF mode
5 - Yes you can (shuffle via RPT but)
-SD
-Mini SD
-Micro SD
-XD
-CF Type I
-CF Type II
-SM
-XD
-MS ( Memory Stick)
-MS Pro
-MS Pro DUO
-Translflash
- etc
So I assume one of these cards is the format that simply slips right into the dash, and that's the card I would want to buy. So what format would that be?
The part I am still not clear on is , what is the native format for the flash card reader in the dash....ie, if I dont want to bother with adapters, what does the slot accept directly? The formats I know for cards are:
-SD
-Mini SD
-Micro SD
-XD
-CF Type I
-CF Type II
-SM
-XD
-MS ( Memory Stick)
-MS Pro
-MS Pro DUO
-Translflash
- etc
-SD
-Mini SD
-Micro SD
-XD
-CF Type I
-CF Type II
-SM
-XD
-MS ( Memory Stick)
-MS Pro
-MS Pro DUO
-Translflash
- etc
CF Type I is what fits directly in the dash.
on
Originally Posted by GoofyG28
Does anyone foresee any compatibility issues if I get an SD-to-CF adapter? I have mostly SD cards, although I also own SmartMedia and MemoryStick. I really wnat to avoid adopting another new card type if I could help it.
Compatibility with other media:
If a commercially available CompactFlash
adapter is inserted into the slot, your
memory media can also be used.
According to that, using other media types with an appropriate adapter should work fine.
Freeman186
09-06-2023 10:07 AM
Thebaws11
07-02-2021 11:36 AM
Mad A
Not G35 Related
12-08-2015 01:45 PM
