Drive-by-wire?
Old Nov 8, 2006 | 04:40 PM
HuKaShI's Avatar
Drive-by-wire?
Does anyone know if the '07 is a drive-by-wire setup?
Old Nov 8, 2006 | 04:49 PM
DWP's Avatar
DWP
Do you mean steеring without a direct mechanical connection between the steеring whеel and the front whеels? Don't think so. The specifications for the new G35 describe the steеring as "Power-assisted, vehicle-speed-sensitive rack-and-pinion", which reads to me like a direct mechanical connection. The only stеer-by-wire passenger cаrs I'm aware of are prototypes on display at аuto shows, not on the road. Don't know about the brakеs or throttlе, but I would assume that they are of the traditional hydralic/mechanical type.
Old Nov 8, 2006 | 04:52 PM
max2k1's Avatar
I think the OP is specifically asking about the throttle.
Old Nov 8, 2006 | 04:53 PM
Msedanman's Avatar
O.F. Administrator
I believe he is, and I believe it is.
C.
Old Nov 8, 2006 | 04:55 PM
max2k1's Avatar
C.
Yup sorry -- I posted too soon
I think even the prior MY Gs had a drive-by-wire throttle.
Old Nov 8, 2006 | 05:12 PM
DWP's Avatar
DWP
In that case, I stand semi-corrected:
http://www.worldcarfans.com/print.cf...3.003/lang/eng
(Fifth section, sixth paragraph of the article)
Old Nov 8, 2006 | 05:28 PM
HuKaShI's Avatar
Yes, I was referring to the throttle. I figured as much since it has VDC.
My TL has drive-by-wire thus enabling it to have VSC.
Old Nov 8, 2006 | 05:29 PM
SilverII's Avatar
Drive by wire enables the ECU to cut power.
rejin267
Jun 30, 2013 07:50 PM
visualfusion
Feb 22, 2005 05:24 AM
Robin
Jan 19, 2003 09:58 PM
