Drive/Drive Sport on Transmission?
Old Nov 12, 2006 | 10:02 PM
kca2000's Avatar
My dealer told me there are 3 ways for the transmission to operate. "Drive" is one, "Drive sport" another, then "full manual". I dont recall 2 settings on the Automatic anywhere. Is this true or no? Anyone with a 07 wanna comment?
Thanks in advance!
BTW I won't have my 07 till Thursday... In case the sig. threw someone off.
Old Nov 12, 2006 | 10:09 PM
coupin827's Avatar
Yes this is true, there are a few threads up on the forum that refer to this.
Old Nov 12, 2006 | 10:22 PM
Dr Dino's Avatar
When you slide the gear selector staight back, that is drive. Then when you slide the selector to the left that is sport. Finally while still in the left position you shift up or down you switch from sport to manual. That is how you get 3 modes.
Old Nov 13, 2006 | 12:54 AM
kca2000's Avatar
Well then, thats why i didn't see it. Makes sense. Thanks
Old Nov 13, 2006 | 09:51 AM
G35Now!'s Avatar
Moderation-free
Actually you could call it four modes:
Straight auto
Sport auto
Man shift with shifter
Man shift with paddles
Also, someone else found out that you can actually hit the paddles while in auto (D, not DS), and it will temporarily let you select gears. Not sure how long "temporary" is, haven't played with it enough.
Old Nov 13, 2006 | 10:50 AM
RBull's Avatar
Rated M
^Uhh, only on the sport. He is getting an X.
Old Nov 13, 2006 | 11:07 AM
JWangSDC's Avatar
Donno if you were referring to the paddle comment or not, but otherwise X has the exact same modes.
Old Nov 13, 2006 | 11:26 AM
RBull's Avatar
Rated M
yes. I missed the "^" in my last post.
Old Nov 13, 2006 | 11:56 AM
G35Now!'s Avatar
Moderation-free
Ah, excellent point - thanks for correcting.
Old Nov 13, 2006 | 11:58 AM
RBull's Avatar
Rated M
No worries. Hopefully it served to inform a few more people.
Old Nov 13, 2006 | 04:44 PM
chuckg35's Avatar
The paddles will shift the car in any mode any time. In D mode, the gear selected is shown by number on the dash but after a few sec. it reverts to "D" again.
Old Nov 17, 2006 | 02:04 AM
kca2000's Avatar
I have the car now. It works great. The regular drive mode seems a little aggressive for "normal mode" but im getting used to it. I have not tried drive sport because im trying to keep the revs down for the break in. Ill put this car through its paces after the 1200 mile mark
Old Nov 17, 2006 | 10:09 AM
RockyR's Avatar
I think Sport mode is the better mode for breaking in the car. Unless you give it full throttle, the revs stay below 4000 rpm.
Why is it better? Sport forces the car to use more of the rev band from idle to 4000. I also read somewhere that when breaking in a car, you shouldn't allow the engine to lug at low rpm's. Sport mode will keep the car in a lower gear and keep the revs a bit higher.
I have to say that I love the new auto trans. Leagues better than the one in my old 2003 G.
Old Nov 18, 2006 | 12:56 AM
Hypnoz's Avatar
Is it? I saw a thread on here with a lot of people saying it is the same transmission and how dissappointed they were with it (especially compared to the 335i).
Old Nov 18, 2006 | 01:16 AM
RockyR's Avatar
I've driven the 335i. Not measuraably better than my 2007G's.
My 2003 downshifts like mollasses, won't allow downshifts that end up much above 4000rpm. My 2007 downshifts completely before I finish moving the stick back to center detent! And it happily allows downshifts to high rpms. Still breaing in the car, so far I have only allowed downshifts to 6000 rpm.
