Has anyone dynoed their VQ35HR yet?
Old Nov 29, 2006 | 02:10 PM
Diesel350's Avatar
Anyone plan to?
What are your guesses for dyno numbers?
I think it will probably be around the 270HP range stock.
Old Dec 2, 2006 | 04:15 AM
Hypnoz's Avatar
bump....
Old Dec 2, 2006 | 06:43 PM
bponce23's Avatar
bump...
Old Dec 2, 2006 | 07:45 PM
Klubbheads's Avatar
Originally Posted by bponce23
bump...
Originally Posted by Hypnoz
bump....
+1.
Old Dec 4, 2006 | 10:18 AM
Hypnoz's Avatar
Come on.... how could so many people have this car and not one person has dyno'd? That would be the first thing to do after break-in....
Old Dec 4, 2006 | 10:22 AM
N50's Avatar
N50
I don't think too many people have finished their break in periods yet. Be patient...someone is bound to dyno it.
Old Dec 4, 2006 | 10:46 AM
RBull's Avatar
Rated M
Originally Posted by Diesel350
Anyone plan to?
I think you're a little on the optimistic side. My guess is 255-260 for the 6mt and less for the AT.
Old Dec 4, 2006 | 11:02 AM
kring's Avatar
Why wouldn't it be 300-310? the SAE regulations for HP measurements are at the rear wheel and must be witnessed by a separate 3rd party in order to carry the SAE certified HP rating.
What does the stock 06 Coupe and Sedan come in at? these were off the old SAE specifications which was not required to be at the rear wheels, so naturally they could be lower.
from what I'm reading, the 07's are flat out faster... that doesn't happen when the car gets less HP/Torque.
and why would the 6MT have any different rating then the AT? Why would the AT be lower?
Old Dec 4, 2006 | 11:11 AM
N50's Avatar
N50
^You need to take in consideration hp at the crank vs. hp at the wheels. The more hp at the wheels, the better obviously. Most rear wheel drive cars have a up to 20% hp loss through the drivetrain before it gets to the back wheels. So 255 sounds about right.
Edit: I'm not exactly sure what standards are what any more as far as SAE goes. Haven't followed that closely.
Old Dec 4, 2006 | 12:15 PM
Sedanman07's Avatar
Waxer
If this was true then our engines would be pushing 350+ hp. Check out:
http://www.sema.org/main/semaorghome.aspx?id=56097
Old Dec 4, 2006 | 12:45 PM
Coach's Avatar
The SAE specs you are referring to are measuring crank HP, not rear wheel HP.
An AT will likely have less rear wheel HP due to more driveline loss than a MT, even if the SAE spec'd. crank HP is the same.
Old Dec 4, 2006 | 01:04 PM
Jeff Flowerday's Avatar
Yah that would be close. I'd say 250-255 for the manual and 245-250 for the auto. After 10,000 miles the manual might start closing in on 255+.
Here's a dyno of the M45 which of course has an extra 19hp at the crank.
http://forums2.freshalloy.com/showthread.php?t=158754
Old Dec 4, 2006 | 02:07 PM
RBull's Avatar
Rated M
You've got the answers to your questions by now through other helpful posts. Your source for information is grossly misinformed.
Old Dec 4, 2006 | 02:08 PM
RBull's Avatar
Rated M
Probably true. I was being liberal not wanting to burst the OP's bubble too badly.
Old Dec 4, 2006 | 04:40 PM
Skaterbasist's Avatar
Retired SuperMod
bump for a dyno
