First Rattle:(
Old Dec 5, 2006 | 05:27 PM
Railgunner's Avatar
First Rattle:(
Well, with my new wheels my Journey rides a little stiffer and yesterday I noticed I was getting a rattle from somewhere. Finally tracked it down today and guess what it was...
Remember that rubber molding on the sunroof that was loose on a number of peoples 2007 G35 Sedans? That was what was rattling. Where the top part of the molding fits on the lip next to the glass was loose and vibrating against the glass. I pushed it onto the metal lip (hard) and it's tight again now but since it's just pressed on a metal lip (doesn't snap on, just pressed on) I'm pretty sure it's just a matter of time before it works loose again.
I'm wondering it this part was supposed to have been glued at the factory?
I can't imagine they would think a piece of hard rubber with a groove in it pressed onto a metal lip would stay put.
I'm a little worried about taking it into the dealer because without a TSB
they are probably not going to have any idea what to do about it and
may screw something up messing with it.
Old Dec 5, 2006 | 05:52 PM
chilibowl's Avatar
A trip to the dealership just isnt worth your time for something so small. Just glue it yourself man. You want something done right, sometimes you just gotta do it yourself bro.
Old Dec 5, 2006 | 06:38 PM
GoofyG28's Avatar
I have a rattle, too, but I can't pinpoint where it's coming from, and it doesn't happen all the time, usually in the morning when it's freezing cold.
Old Dec 5, 2006 | 07:46 PM
Christian's Avatar
My salesman told me that the rubber thing on the sunroof was not intended to be glued in place, apparently the same thing is known to happen in the M.
Old Dec 5, 2006 | 07:50 PM
GEE35FX's Avatar
You would think a couple dabs of silicone caulk would keep that rubber strip on.
Old Dec 5, 2006 | 07:56 PM
N50's Avatar
N50
I'm just glad to hear that the rattle was nothing worse and that it was due to a problem already well known.
Old Dec 5, 2006 | 07:59 PM
Garnet Canuck's Avatar
Traveling Administrator
Living in San Fran, you don't know what freezing cold is!
Old Dec 5, 2006 | 08:41 PM
Railgunner's Avatar
That's a good idea. I'll try that.
Old Dec 6, 2006 | 12:41 AM
GoofyG28's Avatar
La la la... Cold to me is under 40°F. Hahahaha Yes, we're spoiled here in the Bay.
Old Dec 6, 2006 | 01:39 AM
ABQ_G35's Avatar
Or blistering heat either Shane!
Old Dec 6, 2006 | 06:20 AM
tappedwire's Avatar
Also have a 2006 Murano and had the same problem. It was causing the sun roof to leak a little and it turned out they had to replace the liner/molding at the dealership.
Old Dec 6, 2006 | 09:22 PM
IllusiveG35C's Avatar
I was hoping a rattles thread wouldn't come up. I am counting down the days until my 04 G35 coupe lease is up it sounds like its going to fall apart. Im very interested in the 4 door but haven't been able to test drive it.
Old Dec 7, 2006 | 09:47 AM
RLampke's Avatar
Better look elswhere - this issue is well documented here.
Old Mar 12, 2007 | 11:37 AM
Tiger's Avatar
Fixed it
I was hearing a slight rattle as the miles went by coming from the sunroof area. After reading through the forum, I was able to pinpoint it to these accordian covers.
Yesterday, I took them loose and placed a few pieces of black adhesive felt to the top side of the hook part of the extrusion. Once I put the covers back in place, they fit much more snug. I have driven it for a day now, and it seems to have gotten rid of the rattles.
Having worked in the auto industry for quite a while, I've learned that adhesive felt and foam pads are the building blocks of most modern automobiles; especially Nissans.
Old Mar 12, 2007 | 11:49 AM
gfmiller's Avatar
A false rattle...
I though my G had developed a rattle in the dash area. It was sporatic, I eventually determined that it only occured when crossing sharp pavement irregularities. Further driving and listening narrowed the noise down to the right side of the dash. Turns out my round-dial type air pressure gage was the culprit. It wasn't moving around the glovebox, the needle was rattling in the guage.
This car is generally very quiet, and so noises I'd never even hear in my other vehicle are quite apparent.
