Any brake experts here?
Old Dec 12, 2006 | 09:49 PM
Railgunner's Avatar
I'm thinking the next mod I might do with my new G is aftermarket slotted rotors and braided steel brake lines.
However, none of the sites that sell rotors has anything listed for the 2007 G35 Sedan. Would the rotors have changed between the 2006 and 2007?
Also, if I wanted to go to an inch larger rotor in the front but use the same factory caliper what would I need? Is there some kind of bracket the caliper mounts on that's is different depending on the size of the rotor or can the caliper be adjusted for different size rotors?
Old Dec 13, 2006 | 12:32 PM
04NismoV35's Avatar
Not an expert but....
The new sport has larger 13" rotors, not sure about non-sport. As for caliper relocation I haven't seen one yet but you might want to check www.RacingBrake.com every once in a while or call them. If the non sport setup is the same as the 05-06 non X brakes then chances are you can use their current kit
Picture Share
Feb 4, 2018 12:41 PM
Gabe83714
Oct 6, 2015 06:40 AM
dcsbh1
Oct 1, 2015 03:15 PM
alinero718
Sep 27, 2015 09:35 PM
