Maybe Infiniti should revise the gauges like this...
Originally Posted by Speedoholic
I actually like the red needles betters. As for the center red box - I agree, it's an eyesore, but it's red for a reason - it's a warnings window.
The LEDs to do the job are 3.5x2.8mm LEDs. Examples are in this link:
http://www.us.kingbright.com/categor...2%2E8mm&Page=1
However. The PCB pads are probably 4 conductor (3 ground; 1 Vcc). You'll have to solder the LED on just 2 of those pads.
You might be able to overcome the red color of the needle with a bright blue LED.
For the LCD, there is a red/orange diffuser that needs to be "cleared" or replaced with a white frost diffuser. Underneat is at least 6 LEDs that light up the display.
That's pretty much it, unless you guys want different colored gauge lighting. Since labels have no color, you can change out the LEDs to whatever color you want.
It's pretty easy. The Z and prev. G needles could be removed, I wouldn't be surprised if these needles can be pulled off as well... who wants to be the guinea pig?
Originally Posted by DaCurryman
I'll admit that I love the idea of an all blue/white combo, but now that I see it in your pic, I'm kinda glad we have it the way we do. The all blue/white seems a little bland. The red/violet/white combo now has enough contrast that it stands out well.
You don't have to stick to pure blue. There are multiple LEDs behind the LCD panel, so you can mix blue and white to give it a light blue color. This will make it more readable at night while contrasting it from the gauge faces.
