Fog Lights On '07
Fog Lights On '07
Has any one changed out the stock fog light bulbs for aftermarket ones? I dont like how the yellow fog light turned on looks with the bluish hid lamp. Also is it possible to do the change? if so which is the best brand to go with? PIAA, SULVANIA??
Originally Posted by Audiophile
I can see no improvement by having the fog lights on, so I just don't use them. Though I did adjust the headlights up just a bit and now visibility at night is superb.
Originally Posted by ChristianN
Here in Canada the day time running lights are the fog lights running at 50% intensity, so it would be kinda cool if the fogs weren't so ordinary looking. I also found one night that the fogs, despite their unusual placement in the main headlight body, are quite useful in cutting through thick fog.
Originally Posted by UltimateGee27
does the US have thse same specs for the daytime running lights..
how did u adjust them up a bit?
was there a control in the car or u had to pop the hood?
Originally Posted by caveman666
I agree they do help in the fog. And I never use them otherwise. I do wish however that they were either better matched light to the headlights, or down below on their own and whiter light.
EXACTLY!!!!
I had to pull both air boxes out and under them towards the fender is what looks to be part of the adjuster, I could not find the end to make the adjustment but because the car is new I could turn the gear itself with a small screwdriver. Parked the car on flat ground aimed towards a building and brought both headlight beams up just a little bit. There is another adjuster towards the center of the light, that is the adjuster for the fog lamp bulb, I tried turning that up a bit as well and still couldn't see any real improvement so I turned them back and left them alone.
Because the beam pattern of these HID's cuts off so sharply, aiming them up just a little bit made a large improvement.
Originally Posted by RED_G35S
i wish the fog lights are located in the bottom of the bumper so i can put yellow bulbs...
The bulbs are easy to get to, you can still change them if you wanted.
no i mean i like the fog lights locate in the lower bumper instead of integrated to the headlights...
Machine Head
19 Inch
Mar 16, 2016 08:55 PM
