Bluetooth Question?
Old Feb 2, 2007 | 01:28 AM
ramo's Avatar
Bluetooth Question?
I have a loaded G35S, and my question is that i was wondering if anyone else here has a problem sometimes when you get in the car and the phone doesn't hook up automatically unless you reboot your phone? Do you think that is a common prblem, or a phone issue? I have a Samsung SCH-a990 from Verizon
Old Feb 2, 2007 | 01:39 AM
G-Whizzer's Avatar
No problems here - Motorola MPx220 / Cingular
Old Feb 2, 2007 | 01:47 AM
Christian's Avatar
I have no problems with that on my Samsung SCH-a900 connecting to the G. I wouldn't rule out the phone being the problem too quickly. This is my last Samsung phone, its a POS.
Old Feb 2, 2007 | 01:54 AM
RED_G35S's Avatar
sometimes i have to turn off and on the bluetooth on my phone in order to connect to the car... i have a sharp phone sx633
Old Feb 2, 2007 | 07:12 AM
Garnet Canuck's Avatar
Traveling Administrator
No problems here with my Razr. That sounds more of a phone issue to me.
Old Feb 2, 2007 | 07:42 AM
randman's Avatar
I have a Cingular 8125. No problems. Works great with the G35's bluetooth.
Old Feb 2, 2007 | 08:00 AM
hokiesean24's Avatar
no problems with my razor yet. its only been like 4 days though... =)
Old Feb 2, 2007 | 08:53 AM
chuckg35's Avatar
same thing happens verry occasionally with my palm/treo 700p haven't figured out why but will be watching battery
Old Feb 2, 2007 | 09:55 AM
Blaxima's Avatar
Yep, I experience the same thing occasionally w/ my LG vx8600
Old Feb 2, 2007 | 10:13 AM
wavelengths's Avatar
Some BT stacks have that issue. Others are just bulletproof.
I'm using a Nokia 8801 and have had zero problems. Though I miss the detailed signal strength indicator I had on the Razr (but sure as heck don't miss that phone!).
Old Feb 2, 2007 | 11:46 AM
kllr13b's Avatar
I have a LG cu500 and it has happened once. The signal indicator works fine on this phone and on my old Motorola V551.
Old Feb 2, 2007 | 12:19 PM
caveman666's Avatar
Samsung A-920 had a couple issues when I first got the car, but ever since it has been flawless. Now I want one that will download whole phonebook at once!
Old Feb 2, 2007 | 12:26 PM
Hikos_G's Avatar
You should only have to pair your phone with the G's BT once and it should recognize it everytime it gets near the car. It could stop connecting if you disconnect the battery from your phone or reset it to default settings to wipe out all your personal BT and other settings.
Old Feb 2, 2007 | 02:34 PM
yidster's Avatar
Its a phone issue for me
I've got the Sprint PPC-6700 and it is definitely the phone. I used to wear an earpiece BG (before G35) and it would have to re-pair frequently. Same problem with the car now.
My work Nokia 6102i hasn't had a problem.
My wifey's Crackberry 7250 works well.
My pop's Samsung A900 is fine also.
Old Feb 2, 2007 | 04:15 PM
cnugs127's Avatar
I have a Audiovox XV6700 and sometimes i can't use the bluetooth feature even though the bluetooth is on and the car reconizes the phone. Not sure how to resolve this yet. Maybe turn the bluetooth off and on like someone else suggested.
