Anyone heard of CarTest?
Old Feb 14, 2007 | 02:52 PM
moose1963's Avatar
I found a program called CarTest where you enter car-specific data and it will generate different results. For example, it will generate Standing Start Acceleration results, Rolling Start Acceleration results, Horsepower and Torque Curves, etc. The product I used was pretty old (last copyright was in 1998), but there might be an updated version. If anyone sees any settings that I should change, please let me know. Here are the results for a '07 G35x (this does not account for the top speed limiter):
2007 G35X
CAR SPECIFICATIONS
Engine Displacement: 3498 cc.
Engine Location: FRONT
Engine Type: NORMAL
Engine Max Horsepower: 306 bhp
@: 6800 rpm
Engine Torque: 268 lb-ft
@: 4800 rpm
Compression Ratio: 10.6 :1
Maximum engine speed: 7600 rpm
Start Engine Speed: 900 rpm
with Clutch: BRAKE TORQUE
Transmission Type: AUTOMATIC
Number of Gears: 5
Gear Ratio 1st: 3.84 :1
Gear Ratio 2nd: 2.35 :1
Gear Ratio 3rd: 1.53 :1
Gear Ratio 4th: 1.00 :1
Gear Ratio 5th: 0.84 :1
Gear Ratio 6th: :1
Final drive ratio: 3.69 :1
Driving wheels: REAR
Car test weight: 3704 lb.
% weight on front wheels: 53 %
Wheelbase: 112.2 in.
Tire section width: 225 mm.
Tire circumference: ft.
Wheel diameter: 17 in.
Tire profile: 55 %
Coefficient of drag: 0.29
Frontal area: sq.ft.
Overall height: 57.8 in.
Overall width: 69.8 in.
Ground clearance: 5.1 in.
GENERAL PARAMETERS
Air Temperature: 65 deg. F.
Barometric Pressure: 29.38 in. Hg.
Relative Humidity: 55 %
Elevation above Reference: 0 ft.
Headwind (+), Tailwind (-): 0 mph
Road Grade (+=Ascend, -=Descend): 0 %
Shift Time, Manual: 0.50 sec.
Shift Time, Auto: 0.30 sec.
Engage Time, Manual: 0.20 sec.
Engage Time, Auto: 0.10 sec.
Clutch Slip Max. Time, Manual: 5.00 sec.
Brake Release Time at Start, Auto: 0.10 sec.
Trans. Engage Method-Lin,Prog,Regr: R
Shift@O=Optim,R=Redline,D=Driver,P=Prog: O
Engine Free Decel Rate: 2000 rpm/sec
Engine Bog Down Decel Rate: 4000 rpm/sec
Engine Wheelspin Decel Rate, Manual: 500 rpm/sec
Engine Clutch Slip Decel Rate, Man.: 250 rpm/sec
Engine Trans. Slip Accel Rate, Auto: 750 rpm/sec
Engine Wheelspin Accel Rate, Auto: 250 rpm/sec
Max. Coefficient of Static Friction: 1.00
Max. Coefficient of Kinetic Friction: 0.85
Coefficient of Rolling Resistance: 0.013
Tire Expansion Factor: 0.020 %/mph
Hot Tire Pressure: 35 p.s.i.
Tire Tread to Section Width Ratio: 90.0 %
Wheel and Tire Weight: 45 lb.
Minimum Engine Speed: 700 rpm
Zero h.p. Engine Speed: 600 rpm
Turbo Start Speed: 3000 rpm
Max. Torque Conv. Slack Until, Auto: 2000 rpm
Low Max. Brake Torque Speed, Auto: 2000 rpm
Time Increment: 0.05 sec.
Start Time after Car Moves: 1.00 ft.
Mechanical Losses-Auxiliaries: 2.00 %
Mechanical Losses-Manual Trans.: 6.00 %
Mechanical Losses-Auto Trans.: 8.00 %
Mechanical Losses-Differential: 4.00 %
Mechanical Losses-Axles & Shafts: 5.00 %
Mechanical Losses-Torque Converter: 3.00 %
Max. Clutch Slip Losses, Manual: 10.00 %
Max. Trans. Slip Losses, Auto: 15.00 %
Max. Torq. Conv. Torque Multiplier: 2.25
Effective Engine Radius: 3.0 in.
Drive Shaft Radius: 1.0 in.
Center of Gravity from bottom: 30.0 %
Graphics Aspect Ratio (EGA): 0.75
Graphics Aspect Ratio (VGA): 1.00
Sound Effects (Y=Yes, N=No): N
STANDING START ACCELERATION RESULTS
Starting vehicle speed: 0 mph
Starting engine speed: 900 rpm
Starting gear: 1st
Optimum Shift Points:
1st 7600 rpm @ 43 mph
2nd 7600 rpm @ 71 mph
3rd 7560 rpm @ 109 mph
4th 6710 rpm @ 149 mph
Time to Speed:
0- 30 mph............ 2.1 sec.
0- 40 mph............ 2.9 sec.
0- 50 mph............ 4.5 sec.
0- 60 mph............ 5.7 sec.
0- 70 mph............ 7.2 sec.
0- 80 mph............ 9.6 sec.
0- 90 mph............ 11.8 sec.
0-100 mph............ 14.3 sec.
Time to Distance:
0- 100 ft............ 3.1 sec.
0- 500 ft............ 7.9 sec.
0-1320 ft.(1/4 mile). 14.4 sec.
@ 100.2 mph
Top Speed............. 160.1 mph
The 1/4 mile time seemed in line with some times listed in this forum. I was wondering what you all thought of this and could it be useful in any way to determine what the effect of a mod could be?
Old Feb 14, 2007 | 03:08 PM
coupin827's Avatar
I dunno, they are claiming 0-60 in 5.2 for the new sedan, 5.7 seems high.
Old Feb 14, 2007 | 03:24 PM
moose1963's Avatar
I thought so to, but I saw some times posted by others (https://g35driver.com/forums/showthr...ighlight=track) and the 1/4 mile seemed right on with their times.
Old Feb 14, 2007 | 03:37 PM
coupin827's Avatar
I think a lot of people who are tracking it, may still be in break in or have just gotten done with it.
Plus, they may not be able to drive either, hehe.
Old Feb 14, 2007 | 04:22 PM
CarNutz's Avatar
I agree.. Too many other variables for the 1/4 mile times.
Engine also needs 15K miles on it to really loosen up.
Dallsinghjr1
Sep 17, 2023 11:25 AM
Rose M
Oct 12, 2015 10:00 AM
dcsbh1
Oct 1, 2015 03:15 PM
5150DS
Sep 26, 2015 07:47 PM
