Does AWD do anything for dry pavement handling?
I know, I was being a little sarcastic
Originally Posted by HyperM3
Of course, this is the reason they banned quattro from audi racing. They kept beating all the BMW's and BMW complained that it was an unfair advantage. At first, they mandated a weight bias(putting about 200lbs extra in the front of the audis) but then they still kept winning. So then they just banned Audi from using quattro alltogether.
FWIW, I feel more confident handling in my A4 than I do my M3. Its just planted that much more and is nearly impossible to get into trouble with.
Originally Posted by John2.5RS
it's not always the car, mostly the driver
Originally Posted by mfecko
Also note - that that article is based on the 05 (or 06) G35x model, not the 07. Different car may result in differnt results. I wouldn't jump to the conclusiosn that the above would hold true for the 07 G35S.
Originally Posted by dopey
two words.
snow tires.
most people with AWD tend to keep all seasons on for simplicity.
most tire tests show that traction with snow tires on RWD is better than AWD in general.
snow tires.
All things being equal (including tires), do you have an opinion as to which provides better traction - AWD or RWD? What about speed (lap time)?
Originally Posted by Blaxima
I find it interesting that when someone askes about AWD vs. RWD, it always turns into a comparison of tires. Are you implying that a RWD w/ snows is better than an AWD w/ snows? Or are you saying that snows are better than all season?
However, reality doesn't consist of apples to apples. Most people with AWD don't bother with separate summers and separate winters. Those that do will absolutely get better winter traction. But for the vast majority of AWD owners, they stick with all seasons. In that case RWD w/snows is at least as good traction wise.
Tirerack recently did an apples to apples comparison of rwd and awd and yes awd managed to beat out rwd in acceleration tests. Well, at least it was apples and apples in terms of tires . They used a 4wd porsche cayenne vs a rwd BMW 325i.
Originally Posted by CarNutz
Would be interesting to see the same driver take a RWD and then an AWD version around the same track.
As far as traction goes in the snow, AWD is better than RWD with the same tires.
Snow tires make a HUGE difference in BRAKING, a fairly large component of driving.
I saw that vette easily pull away from you, then only to slow down and wave you by...
The ability to put down power so much earlier than most RWD cars out of a corner gives an AWD car a tremendous advantage point-to-point.
I am still perplexed about the claim that a RWD car with snows has a traction advantage over an AWD with all seasons. This has not been my experience. I had snow tires on my old mustang lx 5.0 and the minute you would get in the throttle any more than maybe a quarter it would step out sideways. And boy did you ever have to feather it starting from a stop and going up a hill. I pound the heck out of our X and it always feels in control (with all seasons) mash the throttle to the floor from a stop with VDC off and it will spin but will stay pretty straight and accelerate WAY faster than any RWD with snows I've ridden in. My father in law's S420 merc never makes it up our driveway (hill) with his snow tires....I have no problem at all. Maybe if the RWD car was woefully underpowered and heavy it might have decent grip, otherwise I just don't see it.
Originally Posted by demoncleaner
I am still perplexed about the claim that a RWD car with snows has a traction advantage over an AWD with all seasons. .
I'm running great snows on a high-hp RWD car right now, and the "X" car could have walked it handily with the OEM Turanzas in a 0-50 race.
Each individual snow tire has better traction than each individual all season tire.
However, since 100% of the power is going to two sets of tires vs up to 50/50 in slippery conditions, even though the RWD snow tires have better traction, you're going to be providing more power to them.
AWD tends to be more predictable all the way around. If you are familiar with your vehicle, RWD with snow tires is just as predictable, but just in a different way. If you aren't familiar with either vehicle, yes, AWD will be more intuitive from a start.
But you're right. it's easier to break out the rear end of a RWD even with snow tires assuming the same amount of power is being pushed into 1/2 the number of wheels. A good driver who takes the time to understand how to drive their car on ice/snow RWD with a good set of snows can be better than AWD with all seasons, especially when you factor in stopping traction.
We just got a lot of snow here in Chicago. And by my GF's place the street and alleys had not been plowed after 2 days. My 05x with 18" high performance all-seasons made it through and parked ok twice. It was really bad. None of my past cars would have made one of the turns up an incline I had to go through (over 8" of heavy mush). I put on the snow switch and away I went. I would not have recommended it to any RWD car. But most of the year its a waste of the AWD.
I've been driving RWD cars for a while now in minnesota. The only time I had any problems was when the snow was higher than my car's ground clearance.
AWD or the best snow tires in the world ain't gonna help if you're bottoming out on snow .
I've never taken a day off from work because of snow. I just take it easy on the roads.
With regards to the pros/cons of "RWD with snow tires" versus "AWD with all season", I supposse it also depends on the kind of snow tires used and the kind of all seasons used (not all snows are created equal, same with all seasons). But personally, I prefer AWD with all season than RWD with snow. But, my #1 preference - AWD with snow. With this combination, I am unstoppable!
#30
Edit for add:
In the town i live in its a pretty damn hilly area and when the cops in their cars with their snow tires want to get up a hill in a hurry they do it in reverse. $hit ive seen trucks with chains get caught on our hills. We used to take bets on which cars were going to make it.
